Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Aftermarket Lockers
Old Mar 14, 2007 | 11:59 PM
Dr.Automotive's Avatar
BANNED CROOK
Default Aftermarket Lockers
Anyone running lockers to pull with?
Old Mar 15, 2007 | 01:23 AM
Prozac's Avatar
Default Heavy Duty Driveline Systems
Call Mike Jr. at www.superioraxle.com... tell him Brad said hi
Complete drivelines, lockers, axles, gears, etc... He'll make custom setups for pulling, drags or both...
Old Mar 15, 2007 | 01:36 AM
mobs241's Avatar
no but i have 2 different types of lockers in my jeep and both have done well.
i run an aussie locker in my front end and a detroit locker in the rear..
only problem ive ever had is i used to have a detroit ezlocker and i kept blowing it up. but that was just a lunchbox locker
Old Mar 17, 2007 | 12:40 PM
oldsmokey97's Avatar
i need somethin for my '97!!! cant hook up when leaving the line during racing. Just one wheel peel bullshizzit!!!
Lance
Old Mar 17, 2007 | 01:22 PM
RAT_03's Avatar
One of my friends is running a haisley machine locker, seems to be doing good
Old Mar 17, 2007 | 05:33 PM
DPSolutions's Avatar
All of the top running, competitve trucks in the Indiana area are running welded differentials or true (i.e. ARB & Detroit) lockers, front & rear.
Old Mar 21, 2007 | 10:26 PM
BBD's Avatar
BBD
ARB front and back worked for me.
BBD
Old Mar 21, 2007 | 10:33 PM
Lostnwalmart's Avatar
i want a from arb and rear detriot but not for pulling.....
Old Mar 22, 2007 | 09:22 PM
PERFORMANCETRUCK's Avatar
Default Locker Set Ups For Pulling
I'm Building Custom Inner Axle And Locker Set Ups For The 94-02 Dana 60 Dodge Front Ends. My Kits Upgrade To 1.5" 35 Spline 4340 Chromoly Inner Axles And Are Custom Made To Length And Also Replace The 2 Piece Axle Set Up On The Long Side Axle To Eliminate Problems Locking In 4wd And Breakage Issues. With This Set Up You Can Use Trac Loc, Arb, And Detroit Lockers.
Old Mar 22, 2007 | 09:55 PM
IC Smoke's Avatar
I have a Detroit locker in mine, works great! clatter from spinning on wet pavement will scare a passenger!
Ian
