what tranny fluid?
Old Oct 2, 2010 | 10:03 PM
ehaze's Avatar
Default what tranny fluid?
currently have a ATS tranny installed and need to change the fluid.
what should i go with?
Old Oct 2, 2010 | 11:56 PM
promodcummins's Avatar
Only use ATF +4 fluid. I tried running Dextron 3 and tranny shifted like crap. I now put some Amsoil ATF +4 in it and it seems to shift a little bit later and firmer but I dont mind.
Old Oct 3, 2010 | 09:22 AM
ehaze's Avatar
are you saying to stick with the stuff they sell at autozone or go with something better like amsoil?
Old Oct 3, 2010 | 10:09 AM
wildbill's Avatar
Go with Valvoline at the minimum. Or if you can afford it, go with Amsoil.
Old Oct 3, 2010 | 06:44 PM
ehaze's Avatar
order the amsoil online or get it local?
Old Oct 3, 2010 | 07:20 PM
wildbill's Avatar
Local if you got a supplier near by. Or if you can wait a few days, Heath can get ya some coming. He's the supplier for this site.
Old Oct 4, 2010 | 11:25 AM
ehaze's Avatar
ATS said my setup holds between 24~25 quarts of fluid.
assuming this number is for a completely new/empty system.
any suggestions on how many quarts or gallons i should purchase?
Old Oct 4, 2010 | 11:53 AM
CumminGetchaSome's Avatar
I would ask them since its under their warranty. If it messes up running something they don't approve of they may decide to ditch your warranty.
Old Oct 4, 2010 | 11:54 AM
NadirPoint's Avatar
If they put a double deep pan on it will take about nine quarts to refill after a drain, assuming you don't empty the TQ converter. I like to loose the valvebody and let the converter drain so it'll take closer to 20+ quarts, depending on how much stays residual in the lines, cooler, etc.
Old Oct 5, 2010 | 08:09 AM
ehaze's Avatar
from ATS:
The entire system holds 24-25 quarts. You can use any brand as long as it meets at least Dexron III standards.
Regards,
-joel
how do you access the valve body?
