gauges wont work & gearing issues my first cummins in need of some help.?
I just bought my 99 dodge 2WD 5 speed.. It used to be a gas truck and a body shop built it for towing, They put a 97 cummins motor and tranny in it it has 150hp injectors and new turbo (32lbs.) but for some reason with the stock 5 lug rear end it just seems to be really low geared ??? Any advice for me without swapping to a diesel rear end? And the rmp gauge and the odometer doesn't work the previous owner said that the shop he took it to said something about the pcm/ ecm?? other then that it seems to run great with no probs....
your kinda screwed there because the diesel rear ends are 8 lug you can do it but you will have 5 on the front and 8 on the back
but it can me done
find another rear and roll it under there
or just change your gear ratios
but it can me done
lik i told ya in chat, a stock half ton axle wont hold up to the torque of the diesel engine. as far as the tach and speedo not working, thats something we cant help with with out knowing the truck, and seeing how the shop that did the swap made them work, or if they ever did work.
hope ya get it figured out
I just bought my 99 dodge cummins.. It used to be a gas truck and a body shop built it for towing, They put a 97 cummins motor and tranny in it it has 150hp injectors and new turbo but for some reason with the stock 5 lug rear end it just seems to be really low geared??? Any advice for me without swapping to a diesel rear end? And the rmp gauge and the odometer doesn't work the previous owner said that the shop he took it to said something about the pcm/ ecm?? other then that it seems to run great with no probs....
Fill out your Sig.
The truck is 2wd.... So i cant just put taller gears in it? the previous owner said it has only went through 1 rear end since the conversion which was 3 years ago.?
How do i fill out my sig??
Last edited by 99dodgecummins; Oct 3, 2010 at 07:24 PM. Reason: Automerged Doublepost
coryfast
Jul 6, 2015 06:02 AM
rschriek
Feb 3, 2015 10:13 AM
metrickjb
Jan 21, 2015 04:16 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
