Amsoil Visit - Amsoil
Oil change advice?
Old Oct 2, 2010 | 06:57 PM
promodcummins's Avatar
Default Oil change advice?
I just put in some Amsoil 15-40 Marine oil and Amsoil synthetic filter. Btw, thanks Heath. Could I go a straight 15k on this setup or should I change filter at 7500 , then go another 7500 miles. How are most of you running your oil changes with no bypass filter. Thanks
Old Oct 3, 2010 | 03:50 PM
Heath's Avatar
Authorized Amsoil Dealer
Since this appears to be your first change to synthetic, I think changing the filter at mid stream is a real good idea. IF the engine has any build up, the syn will start to clean it and could shorten the life of the filter. Most of the time I recommend running oil and filter shorter the first but changing the filter serves the same purpose.
Old Oct 3, 2010 | 06:16 PM
tb6.9ford's Avatar
i was wonderin what would be the best oil for my truck. its a 85 f250 with a 6.9 in it with about 193,xxx miles on it. Any ideas?
Old Oct 4, 2010 | 02:17 PM
Heath's Avatar
Are you wanting to change to synthetic? Couple things to consider with your truck due to the higher miles and age.
Does it currrently use or leak oil? If so, to what degree. Chances are it won't get any better and could possibly get worse. I changed over a truck at 269,000 that had small leaks and used some(1qt/3000), but I did it anyway. It actually improved over time (took 15k to get there) and it went down to 1qt/4500miles. It can happen but I think it's rare.
That being said and you still wanted to try it, the HD diesel and marine(15/40) is the way to go.
wlofton
11
Jun 26, 2018 08:58 AM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
ctjkelley
Jun 3, 2015 06:01 AM
J_stout
Feb 21, 2015 11:40 PM
