swapping input shafts
Old Oct 2, 2010 | 05:01 PM
rednekroper05's Avatar
Default swapping input shafts
how hard is it to swap the 1 1/4" shaft on the the nv4500 to the 1 3/8"?
Old Oct 3, 2010 | 11:31 AM
thebullet83's Avatar
there was a thread somewhere a while back with pics, but can't find it.
if memory serves: alls you do is unbolt the input shaft bearing retainer, pull that off, pull the input shaft out and change it. it didn't look or sound that hard to do. just search around a lil for it, and good luck.
Old Oct 3, 2010 | 06:33 PM
Dirtclod's Avatar
It also depends on the year of the trans. If your going to put a 1 3/8 gm shaft in, they had two different first gear ratios, I think 93 was the split. The newer trans has the same 1st ratio as the 1 1/4 input trannies, otherwise you will also need to have the cluster shaft gear. I have an input shaft and cluster gear from an earlier style trans if you like, gm though, the dodge shaft is longer, little jumbled, sorry, but I think I got it all there.
Old Oct 8, 2010 | 07:12 PM
also when i swap the input shafts will the fractory size pilot bearing work or will i need a differnet one. Also its a dodge nv4500 im going from the 1 1/4 to 1 3/8
Greywolf
Feb 17, 2015 06:37 PM
ERK
Jan 23, 2015 05:03 AM
woodsman27
Dec 9, 2014 09:55 AM
gyayo2012
Nov 15, 2014 08:11 PM
robbyS
Nov 11, 2014 02:39 PM
