Need help please
Old Oct 2, 2010 | 01:26 PM
sswebber700's Avatar
Default Need help please
I changed my fuel filter and now my truck will not purge the air out of system...any ideas would be appreciated.
Tried reseating filter and a new one no luck so far..
Sends no fuel to the top filter bowl...
Last edited by sswebber700; Oct 2, 2010 at 01:26 PM. Reason: Automerged Doublepost
Old Oct 2, 2010 | 02:16 PM
shooter 7's Avatar
can u hear pump run when turning key to 'on'
Use OEM filters & new o rings. o rings fully seated? with it all buttoned up & key "on" , try & spray soapy water around filter housings, any bubbles? Bubbles indicate leaks.
Old Oct 2, 2010 | 04:40 PM
Mdub707's Avatar
A lot of times it's the frame mounted one that causes issues. It is really hard to tell if it's fully seated without a fuel pressure gauge.
I'd pull that cap off, put some oil on the o-ring and try re-seating it.
Like shooter said, can you hear the pump kick on?
