taking longer to start
Old Oct 1, 2010 | 02:00 AM
hot_link's Avatar
Default taking longer to start
2006 f-250 w/ 115k mi. the longer it sits without running the longer it takes to start up. i havent started cycling the glowplugs yet, but if it sits for 24 hrs, it takes several seconds to start. general starting is taking longer than it should, but the longer it sits the longer it takes to start?? has anyone ran across this yet?
Old Oct 2, 2010 | 10:39 AM
Mdub707's Avatar
Could be a number of things. Hard to tell without more info. Have you tried getting it scanned to see if any codes come up?
Old Oct 2, 2010 | 08:42 PM
hot_link's Avatar
no i havent done anything yet. the check engine light hasnt came on yet.
Old Oct 3, 2010 | 12:10 PM
Mdub707's Avatar
It's not uncommon to have "soft codes" that don't throw a check engine light. It may still have codes coming up. Have you had your batteries load tested? Have they ever been replaced? That'd probably be the first place I'd start. From there, I'd test the FICM, then see if you can get a cylinder contribution test done after. Do it in that order. Start with the batteries though, that's easy to have checked.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
