Injection pump issue. NEED HELP
Old Sep 30, 2010 | 06:22 PM
wpg6.5's Avatar
Default Injection pump issue. NEED HELP
So i turned my turned my truck on after just driving it and it started funny, then when i put it in reverse it kinda chugged, there is now a loud knocking( injection pump?) and loss of power. i drove it home which is about 2 km. a code came up cant remember the number but the code is ; injection pump metering control, cam, rotor or injector.
So i know theres a problem, if anyone can help me figure out the problem and have some possible solutions that would be awesome.
truck has 296000kms, k&n, 4" straight pipe, fluidamper, and apparently marine injectors, a junkyard injection pump with X amount of kms.
Old Oct 2, 2010 | 06:07 PM
Crazy's Avatar
did you check see if your LP is working , i seen bad LP set codes of before if the IP doing the sucking for fuel it is going be down on power and make some loud sounds and if you keep driven it like that you will kill the IP
check LP open t-valve turn key on see if fuel coming out when glow lights on or start truck and open t-valve see if stay running and coming out
Old Oct 2, 2010 | 06:13 PM
Woody35's Avatar
what brand of injectors do you have if there not bosch or delphi there probably junk. how old is the pmd?
Old Oct 3, 2010 | 11:07 AM
wpg6.5's Avatar
I have not been driving it, just the once back to my place. im not sure of the injectors or pmd the original owner put the injectors in, and the pmd is relocated and heat synced so i wouldent expect a prob from it could be it tho. the trucks at a shop right now getting assesed but ill probably do the work myself. has anyone replaced the electronic ip and is it harder or easier then the mechanical?
Old Oct 3, 2010 | 11:19 AM
Crazy's Avatar
where is the PMD relocated to is the intake or front bumper, if on the intake bad place still to much heat for it front bumper better place
how R&R INJECTOR PUMP
Now get yourself some good ziplock bags, and use them to hold the bolts you remove. Keep them in groups, like for the intake and the alternator bracket. This helps tremendously when putting it all back together. Some of my bags only had 3 bolts in them.
Unplug wire harnesses as you need to, but label BOTH ends. GM makes it hard to plug up the sensors wrong, but why take a chance. A small tape flag with "A" "B" "C" and so on, on both sides of the plugs make it easy later.
Remove the upper and lower intakes seperatly. Getting the intakes off is not as daunting a task as you would think. Make a sketch of what holes hold bolts and what holes hold studs. Dont forget to unbolt the fuel filter, You dont have to remove it, but it has to come off the intake. A 15mm deep 6 point socket and a speed handle makes the job pretty easy. Dont unbolt the coolant crossover. It can stay in place. Stuff a shop towel into each intake port to keep anything from falling down into the engine.
Once the intakes are off, you will see the pump, and you will dispair at getting the injector lines off. Follow the line back from the #1 cyl, and mark it at the pump. It should be on the drivers side of the pump, just above halfway down. I use a small zip tie on the nipple to mark it, just so you dont loose track of the #1 spot on the pump.
Remove the #1 and #3 line nuts at the injectors and remove the #1 line nut at the pump with a 3/4" wrench. Carefully slide (DONT BEND) the #1 line back in its bracket just enough to allow the wrench to fit on to the #3 line nut. Remove the #3 line nut and remove that pair of lines from the truck. LABEL EACH LINE NEAR THE PUMP END!
Now you can remove the line nuts for the lines on the top of the pump (8-7-2 and 6). If you undo the lines at the injectors, you will find you can move them a little for wrench clearance. I wound up leaving the 6-8 pair attached to the injectors, because getting to them was a pain in the @ss.
Before getting the bottom 2, I removed the cap over the fuel solenoid, and undid the wires. Getting the lines off is not fun, but its not impossible. You just got to work at it.
as each pair of lines comes loose, remove it from the truck. (you did label them, right?)
Now comes the fun part. It helps to have nerves of steel.
Remove the oil fill tube and grommet off the front of the timing cover. Inside you will see a large nut and hopefully some smaller nuts. You may have to rotate the engine. Use a 15mm on one of the damper bolts and turn in in the 'tighten' direction. Grab some help, and give them a mirror and a light and have them stop you when one of the smaller bolts is inline with the oil fill hole. Remove this bolt. and rotate the engine again. Repeat until all three bolts are out.
MAKE DAMN SURE YOU DONT DROP THESE BOLTS INTO THE ENGINE. In this one area, you want to work slowly and cautiously! As soon as the bolts were finger loose, I stuck my finger in the hole and used my fingertip to make sure the bolt stayed in the socket. Painful, but worth the effort.
After all three bolts are out of the gear, you may remove the 3 nuts holding the pump on. First scribe a line on the pump bracket that lines up with a distinctive part of the pump. It does no good to draw a line on the pump and bracket if you are replacing the pump. there is a part of the pump flange that angles down, I used that as my reference.
Start at the one on the lower passenger side. It is the hardest to get to, and you might as well get it while you are fresh. I used a standard 15mm wrench with no modifications. You may want to bend or grind on the wrench for clearance. It may make it easier, but its not neccisary. Then get the drivers side nut, and finally the top one. With all three nuts off, now the pump will slide out. Remove and discard the gasket.
I'm not sure if you can pull the timing gear out of mesh or not, but I dont think you want to find out. BE VERY CAREFUL AROUND THE TIMING GEAR!
When installing the new pump, rotate the pump so the index pin in the gear hub is aprox. in the same place as the old pump. NOTE! GM, in their infinate stupidity, put the index pin in the same bolt circle as the bolts. This means its entirely possible to stick the index pin through a bolt hole and you wont know it until you try to install the gear bolts and nothing lines up. I had the pump and all lines on when I relized that I did JUST THAT! Talk about excessive profanity!
For that reason, I recommend putting on the top pump nut to hold the pump in place, and then the gear bolts, before doing anything else. I used blue locktite on those bolts. I found using a small mirror to help get the bolts lined up with the holes helps alot.
Install the other two pump nuts. How, you ask? Simple (sort of...) I use a coat hanger to fashion a long wire with a small hook. I hung the nut off the hook and used a long screwdriver to start the nut on the threads. Its not easy, and can frustrate the hell out of you, but if you stay with it, the nut will eventually start. Have a magnetic pickup handy for when (not if) you drop and nut and have to fish it out from underneath the pump in the engine valley.
Once the pump is line up and the 3 nuts secure, go about re-attaching the bottom injector lines on the pump (now aint you glad you labeled everthing?)
the firing order is 1-8-7-2-6-5-4-3. Repeat this mantra every time you install a line, checking and rechecking over and over.
Once you got the bottom lines hooked up, install the Fuel solenoid wires and cap, and reattach the remaining injector lines.
Once I had all the injectors lines on and wires hooked up, I removed the shop towels and tried starting the truck. A 6.5 is more than happy to start and run will the intake off. I DO NOT recommed this unless you have ***** of solid rock. You could very easily suck something into an intake port and do something dreadful to the motor. I did this just so I could check for leaks and whatnot before putting on the intake.
It took some cranking but it finally started. It took about 30 seconds to purge all lines and settle down into the familiar 6.5 idle. Everthing looked good, so I shut it off and installed the intake, alternator brackets, oil fill tube, and anything else that I had removed.
A quick road test confirmed that everthing was okey-dokey. It is conventional wisdom that you should re-time the pump anytime you mess with it.
you can take from here if you want do it yourself
Old Oct 3, 2010 | 02:08 PM
Woody35's Avatar
heres how you time it
Checking/Adjust injection Timing
This procedure should be used after an injection pump installation or when injection timing needs to be checked or adjusted. A scan tool must be used to check or adjust injection timing. A static timing mark can be used as a reference. If a static timing mark is not present on the injection pump mounting flange, one can be scribed to further assist in how far the injection pump needs to be rotated.
NOTE: There will be no change in engine performance or vehicle driveability if the injection timing is advanced during the Time Set procedure. The injection timing must be sot to the Injection Timing Specifications. If the injection timing is not set correctly, a possible DTC P0216 may set (see DTC P0216, the Conditions for setting the DTC). Refer to Diagnostic Tables . See: Computers and Control Systems\Testing and Inspection
1.Start the engine.
2.Allow the engine to idle at the normal operating temperature.
3.Install the scan tool.
4.Use the scan tool in order to activate the Time Set (if the Time Set has been activated correctly, Des. Inj. Time on the scan tool will read 0.0 degree).
NOTE: The Act. Inj. Time value on the scan tool will fluctuate. The Average reading should be 3.5 degrees .
5.The Act. Inj. Time (scan tool display) should be approximately 3.5 degrees. If not, continue to step 6.
NOTE: If the engine stalls during the Time Set activation, slightly (1 mm equals 2 degrees) rotate the injection pump toward the driver side of the vehicle, tighten the flange nuts and repeat the Time Set.
6.If the injection timing needs to be adjusted, continue. If not, this indicates that the adjustment is complete.
7.With the engine OFF, use the J 41711 in order to loosen the injection pump flange nuts.
8.Use J 29872 in order to slightly rotate the injection pump.
9.Set the Act. Inj. Time to 3.5 degrees .
NOTE: It is normal for Act. Inj. Time value on the scan tool to fluctuate. The average fluctuation of the Act. Inj. Time should be
3.5 degrees .
10.Continue to repeat until the average fluctuation of the Act. Inj. time is 3.5 degrees .
•If the Act. Inj. Time is above 3.5 degrees, SLIGHTLY (1 mm equals 2 degrees) ROTATE THE INJECTION PUMP TOWARDS THE PASSENGER SIDE OF THE VEHICLE.
•If the Act. Inj. time is below 3.5 degrees, SLIGHTLY (1 mm equals 2 degrees) ROTATE THE INJECTION PUMP TOWARD THE DRIVER SIDE OF VEHICLE.
Old Oct 3, 2010 | 02:15 PM
Crazy's Avatar
Me BAD should have put in timing procedure, sorry
Old Oct 4, 2010 | 12:40 AM
wpg6.5's Avatar
Thanks guys, ill be doing this as soon as its confirmed that its the ip.
nelly559
Feb 17, 2015 06:49 PM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
veggyoilkid
Nov 10, 2014 12:39 PM
