Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
Ford
Old Mar 22, 2007 | 08:56 PM
bway1341's Avatar
Default Ford
THere is a tractor where i keep my horses its a ford 3400 i think can't quit rember but it wont start I arced the starter it spins but using the ingition it wont work does anyony know what to check i beleave the siolond is not getting power.
Old Mar 23, 2007 | 06:12 AM
Heath's Avatar
Authorized Amsoil Dealer
Aaahhh,.the good old days of arching the starter. I remember doing this on one of our tractors. I also had a diesel Olds cutlass in high school. Use to impress the ladies when you could reach way down under the hood and make the car start. It took so little
It was a bad solenoid as you said, but I don't think we tested it, or I don't remember how we did it. Sorry.
Old Mar 23, 2007 | 10:36 AM
CHenry's Avatar
Vegistrokin Bombardier
bad ignition....
Old Mar 26, 2007 | 11:43 PM
Oregonpharmer's Avatar
The 3400 should be a diesel, and if so it has a mechanical shutoff in the injection pump. Just open the throttle slightly, put it in neutral, put the PTO out of gear, and jump your solenoid and it should start right up.
You can trace the trigger wire from the starter solenoid to the safety box behind the lower cowl. That safety box also has a clutch switch that must be triggered by depressing the clutch, a neutral switch from the transmission, and a PTO lockout switch. The safety box is wired to the start position on the key. The solenoid is what usually fails, but if it is stored in a wet or humid location the key switch itself can fail, as can any of the other switches.
Old Apr 8, 2007 | 08:38 PM
saab9k's Avatar
It is most likely the neutral switch in the tranny, there are 2 wires in front of shifters, unplug both, then plug the 2 wires going to tranny together, should start if the switch is the problem
Nov 4, 2014 01:30 PM
Oct 14, 2014 10:10 AM
Oct 14, 2014 08:40 AM
