wtf?
Old Sep 28, 2010 | 12:14 AM
pushingmy6.0's Avatar
Default wtf?
ok. going down the road today doing 70 or so....i go to pass someone and i pretty much had to put the pedal to the ground for it to do anything.. it slow went to 3 grand then the turbo kick in.. it has been doing it for some time now.. i have the edge juice with att, that was on power 5.. is it this edge junk making my truck crazy?
Old Sep 28, 2010 | 05:29 AM
Mdub707's Avatar
Was it pouring black smoke up until it took off? Your turbo vanes may be sticking... not a huge deal, they can usually be cleaned in an afternoon with some elbow grease and a little time.
Old Sep 28, 2010 | 11:35 AM
no.. black smoke starts when the turbo kicks in... my edge is on power 5.. my truck has 102 miles.. think its time for a turbo clean? or vanes? how would that job get done?
Old Sep 28, 2010 | 05:50 PM
Mdub707's Avatar
Black smoke should clear when turbo kicks in, not smoke more, that is exactly opposite of how a turbo charged diesel works, especially true on a truck like ours. If it was a mechanically injected diesel, where more fuel is poured harder and heavier at higher RPM's, and they're seriously over-fueled, then maybe. On our trucks, the turbo should clean that smoke right up no issue. You should ESPECIALLY have no problems cleaning smoke from an Edge on a lower level (is that a low level? What do they go up to?). Your truck has 102k miles or 102? How is the truck used? You tow with it a lot, or just get the kids from school? These need to be RUN.
Here's the turbo cleaning process. At that many miles, you really couldn't hurt anything to do this no matter what.
http://www.forddoctorsdts.com/articl...icle-06-05.php
Old Sep 28, 2010 | 06:14 PM
ntmdtr3fan's Avatar
Sounds like the Vanes to me also. Had my truck doing the same thing last month. Took ti to Ford and the found the Vanes were stuck. They cleaned it since it was still under the 100k warranty. But I ahd no smoke whats so ever from my truck..
Old Sep 28, 2010 | 11:46 PM
ok.. driving home from work tonight the check engine light came on.... so.. do i need to go to ford an have them take a look???
yes the truck has 102k ..i dont tow or anything like that.. right now... Its my daily driver... the edge power 5 is there max power..
Mdub, you are right.. there is no smoke when the turbo kicks in...
