feels like brakes are on
Old Sep 28, 2010 | 12:06 AM
DobermanDiesels's Avatar
Default feels like brakes are on
my 01 47re has been acting funny i changed the solenoid and pressure gov about 2 weeks ago and today i drove out and stoped at a light on a slight hill and when i went to go it felt like the park brake was on it did this off an on all day? any ideas
Old Sep 28, 2010 | 10:34 PM
oudive's Avatar
DobermanDiesel,
When I read your post, the first thing that came to mind is maybe it is in limp mode. I tried to do a quick search, but wasn't finding really what I was looking for. From what I did read, there are no codes for being in limp mode and it is like having no power, maybe similar to what your feeling....not too sure. If you get a chance check for codes any way to be on safe side. Some one also stated something along the lines of the speed sensor that is on the tranny. Figured I would try to throw some ideas out there for ya.
oudive
Old Sep 29, 2010 | 10:28 AM
i checked for codes and not getting anything also i just changed the speed sensor but it may be bad i think i have a gremlin in my truck just yesterday i was driving and i got on it pretty good and my check gauges light came on my oil pressure was at zero as i but on brakes to pull over it jumped back up to normal and would move with the throttle so i came back home it did it again and then came back on still no codes not sure whats going on here
and i got a code out of it p1693 fault in companion module i am wondering if its just not a bug and if i can clear it and roll with it
Last edited by DobermanDiesels; Sep 29, 2010 at 10:31 AM. Reason: Automerged Doublepost
Old Sep 29, 2010 | 10:39 AM
biged681985's Avatar
i would check all ur grounds if u think u may have a problem
Old Sep 29, 2010 | 11:17 AM
How are you checking for codes?
Old Sep 29, 2010 | 07:54 PM
i did the switch trick and went to have it scanned i had it cleared and its not doing the oil pressure drop anymore but i am worried its gonna happen again i swapped the electrics in the vb a few weeks ago but that was simple and i did a clean install i am gonna go through the grounds as soon as this weather breaks but is funny that its doing the trans thing and now this check gauges light the oil pressure goes to 0 and then it comes back could my adr be causing the problem
Old Sep 29, 2010 | 08:02 PM
I think you have a couple of things going on.
The oil pressure issue is likely from a bad pressure sensor.
Old Sep 29, 2010 | 08:05 PM
oudive's Avatar
DobermanDiesel,
I am not familiar with the ADR. As far as the truck feeling like the brakes are on while driving, did it feel that way once you had the codes cleared? I am curious what codes were present that were cleared. Did you happen to get them wrote down. This might help in giving a direction in which to look next. Also have you checked the brake lines to make sure that none of them were collasped, kinked, or damaged?
oudive
Old Sep 30, 2010 | 07:12 AM
i got a code i cant remember the numbers right off but it was a high oil pressure code it feels like its in the convertor not actually the brakes
the number is p0523 oil sending unit high voltage anybody know what the voltage should be at idle im gettin 2.88
Old Oct 1, 2010 | 05:15 PM
well i am just gonna bite it and send my girl to xtreme diesel in yadkinville NC they will rebuilt my trans fully and comes with a 1 yr 100000 mile warranty i just need to decide on a tc and a vb i also am gonna have a new airdog and a turbo on it i will update
DC_DC41
Jul 16, 2015 09:56 PM
Radioking1777
Jun 9, 2015 04:13 AM
Jun 8, 2015 07:10 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
