Just a suggestion:
Old Sep 27, 2010 | 06:06 PM
PaleHROse's Avatar
Default Just a suggestion:
I see a lot of folks having transmission problems and i wanted to suggest something: There's a trick i learned a long time ago[if you drive and automatic] when at a red light or stopped throw your tranny in NEUTRAL! Why? that's when a tq gets abused the most it's like[holding your clutch down on a manual while standing still]. It applies pressure and heat to a transmission that is in brake duty. I also suggest using FULL synthetic in your tranny and change it once a year. If you power brake a lot, a lot of what i just said is multiplied a many times. I abuse and smash my stock tranny all the time and it hasn't failed me yet. Using Valvoline full synthetic and my rear is at least 1000lbs of spinnin force.
Old Sep 30, 2010 | 03:28 PM
wildbill's Avatar
ATF+4 is already a full synthetic.
Old Sep 30, 2010 | 04:27 PM
PaleHROse's Avatar
Thank you sir!
Old Oct 1, 2010 | 02:47 PM
06Dodge's Avatar
FYI, ATF+4 is not full synthetic its made from group III crude oil base stock.
From AllPar,
For the full story behind the development of ATF+4, please see SAE paper #982674.Here are a few tidbits:
The initial development was done using Shell's XHVI base oil. Only much later were other Group III base oils approved. (Currently, SK in Korea and PetroCanada are the only additional approved base oil suppliers.) The use of Group III base oils is probably the leading cause for ATF+4 being a more expensive fluid than ATF+3 (which according to the paper uses a Group II base oil).
Lubrizol developed a new shear-stable viscosity index (VI) improver specifically for ATF+4. The initial tests of this VI improver in the
MS9602 test fluids were so remarkable that Chrysler modified the then-current ATF+2 spec (MS7176D) to include it. Thus ATF+3 (MS7176E) fluid was born; it remained the factory fill until ATF+4. Lubrizol is used in ATF+4 and is required in fluids licensed for compatibility.
The paper noted that one alternative was to use synthetic Group IV base stock, which are even more expensive than the ATF+4 solution, which provided Group IV style performance from Group III stock.
Oil Groups:
Group I base oils can have a mix of different hydrocarbon chains, with relatively little uniformity; these oils are the least refined. They are usually not used for autos.
Group II are the most common base oils in “dino juice,” with good performance in most areas except cold temperature viscosity.
Group III are called synthetic, and have high molecular uniformity and stability. Group III oil bases are used in most synthetic oils.
Group IV are chemically engineered stocks, arguably with the highest performance and longevity.
Old Oct 1, 2010 | 04:10 PM
94cummins diesel's Avatar
thank you sir how can i tell what tranny fluid i have in my truck sounds dumb ik but i bought the truck a few weeks ago ani wanna change the fluid an stuff so whats recommended for a94 cummins auto
Old Oct 1, 2010 | 04:21 PM
wildbill's Avatar
ATF+4 isn't a synthetic blend, or regular oil, so that means it's a full synthetic.
Old Oct 1, 2010 | 10:39 PM
PaleHROse's Avatar
From AllPar,
Oil Groups:
Good post. Thought there was a reason why Valvoline had the need to post"Synthetic" on the can
