Low boost?
Old Sep 27, 2010 | 05:57 PM
hiboy_76's Avatar
Default Low boost?
Hey guys i have a couple questions about my truck.
The first is whey am i only building 27psi of boost? i have the fuel screw turned up, its at run away. the fuel pin has the deepest part forward. and no AFC spring. It also has the 21cm housing.
I have a 58mm S300, where can you buy bigger compressor wheels and housings for these?
Thanks
Old Sep 27, 2010 | 11:28 PM
dieseldawg's Avatar
what are you running for a lift pump?? bigger turbo isnt going to make more boost if you dont have the fuel to burn!!
Old Sep 28, 2010 | 11:25 AM
hiboy_76's Avatar
a holley black 140gph
Old Sep 28, 2010 | 08:35 PM
dieseldawg's Avatar
stock fuel filter???
big lines??
why are you not running an afc spring??
does it smoke like the fires of hell when you stomp on it??
Old Sep 29, 2010 | 12:05 PM
hiboy_76's Avatar
yes stock filter(for now).
stock lines.
wanted it to smoke back before i turned it up and never put it back in, but i probably will to see if it will make it run better at lower rpms.
it smokes pretty good until the turbo lights(about 15-18psi, i'm guessing about 2200-2500 rpms?)
soco
Jul 27, 2015 06:06 PM
chen
May 29, 2015 04:34 AM
robbyS
Apr 16, 2015 02:22 PM
ash23k
Dec 30, 2014 08:31 PM
cameronlee51
Oct 28, 2014 12:33 AM
