low power
Old Sep 27, 2010 | 03:34 PM
stillcummin's Avatar
Default low power
So im searching for the cause here.Ive been hunting this down for 6 months.History on the 4bt.Changed fuel filter,new lift pump, new 75horse edm injectors,I bought used replacement injection pump to remedy the problem,but it only returned.I ran a heavy amount of bad fryer oil and biodiesel through the tank last summer.Probably 30 gallons un mixed filtered veggie oil and 20 gallons of preped b100.In out titration tests our oil was extremely acidic,as it had sat for months in the weather before changing.I ran into a wal with filter clogging issues almost right away.I installed a clear prefilter and kept it on for 5000 miles till all the crud wasnt showing up.My fuel is now clear(petrol diesel only)but im having power issues.Im pickup in the tank has been removed.Im wondering if glycerin is clogging the pickup.i get a good 6psi at the filter but it pulsates severely sometimes.should i drop the tank?
Old Sep 27, 2010 | 06:14 PM
big bad diesel 416's Avatar
Site Sponsor
Ya I would start in the tank it may be the cheapest and easiest thing to do
Old Sep 28, 2010 | 04:58 AM
I have algae!!I dont even know what to do about it.
Old Sep 28, 2010 | 07:41 AM
cummins_guy's Avatar
there is an enzyme that you can buy (I'm assuming you have algae in your tank)
I will try to find the name for you.
Old Oct 9, 2010 | 08:21 PM
92 diesel lover's Avatar
Default alge killer
the stuff we use is called BIOBORE google it and shop around some places must think its gold
fivepointohno
5.9L CR Performance
12
Jan 25, 2016 01:07 PM
robbyS
Apr 16, 2015 02:22 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
