Auto Trans Slippage Question?
Old Sep 27, 2010 | 10:23 AM
01ctd's Avatar
Default Auto Trans Slippage Question?
Hello,
Here's a question with my 47RE. I was going up a decent grade @ 65mph no load then i have the urge to pass another vehicle. I could see my RPM increasing but my speed was slow to catch up. The truck was perfectly fine no shakes no rattle other than slight torque converter slippage, I also bump the brake to see if the would torque converter unlock it does. Driving around in a normal matter the lockout torque converter is not slipping.
I know my torque converter is slipping but how much is normal?
Is it normal for the engine to overpower the lockout torque converter and slip a little?
When should I worry?
thanks
HD
Old Sep 27, 2010 | 10:30 AM
BIG NIG's Avatar
the more it slips, the more friction material gets pumped into your trans after the filter, the more it heats the fluid, and less power to the rear wheels
you want ZERO slip
Old Sep 27, 2010 | 11:41 AM
01ctd's Avatar
i'm only pulling a boat and less than 8K trailer at best, maybe a round bale carrier for the farm. When do I know I need a new torque converter? Sorry i'm new to the diesel automatic. Should have keep my 97ctd with 5speed at-least I know when the clutch is slipping. BTW I still have the NEW CLUTCH for the 97CTD anybody interested? should I start saving $$$$$ for triple lock TC.
Old Sep 27, 2010 | 01:41 PM
01trailerpuller's Avatar
It was most likely not slipping, if you let your foot off it at all it unlocked the TC. It has to relock it before the trans get the direct power. If you don't want that to happen you need a lockup switch. The poor man switch cost $9 to do your self. There is at least one or to threads on here that tell how to do it. The triple is the way to go. But there are a whole list of thing that you should do with it. Other wise you are going to have to drop the trans mulipule times and that gets very expensive.
By the way did those directions I sent you work?
Old Sep 27, 2010 | 02:20 PM
01ctd's Avatar
By the way did those directions I sent you work?[/QUOTE]
I tried and can't pm you since i'm under 10 post
heres my email: cebu99@hotmail.com
thanks
DieselDan_5.9
Jul 30, 2015 07:05 AM
Nu2cummins
Jun 26, 2015 02:30 PM
kydieseltech
May 28, 2015 05:00 AM
br459
Jan 29, 2015 10:21 PM
mtedrick4
Diesel Engine Conversions
Oct 13, 2014 09:25 PM
