Third member
Old Sep 27, 2010 | 08:29 AM
scarrab30's Avatar
Default Third member
I'm kind of curious if anyone has had problems with there rear ends. I pull heavy boats out of the water for a marina (up to 23000 lbs). Ive spun the tires a few times to get up some of the wet ramps. When the rear end temp gets to 150 or i come off a exit ramp after a long ride, I go to take off from the stop, and get a sensation like it's got a chipped side gear or bad bearing. It does'nt matter whether i'm pulling or not. I've eliminated the possibility of u-joints or center support. Thanks Brian
Old Sep 30, 2010 | 03:29 PM
wildbill's Avatar
What have you got your TST set to?? These rear ends weren't made to handle much more than stock, especially if your pulling an extremely heavy load uphill.
B S
Aug 16, 2015 10:46 PM
Melman
Jun 16, 2015 03:32 PM
oneloud59
8
May 16, 2015 04:24 PM
Chasebait18
Feb 3, 2015 08:17 AM
Regcabguy
Jan 21, 2015 09:28 PM
