torque loc switch
Old Sep 26, 2010 | 05:36 PM
Duckdodgeman's Avatar
Default torque loc switch
I just installed the torque lock switch following the tst wiring diagram but i keep getting a check engine light when i flip the switch? I s this normal or is there a way around this problem? When i dont use the switch i can erase the codes and they dont come back unless i use the switch again. Any help would be great!
Old Sep 26, 2010 | 07:29 PM
94dizzyram's Avatar
did you put the jumper wire in.
Old Sep 26, 2010 | 08:08 PM
I removed the tranny relay and placed the jumper wire in it.The codes i am getting are p0622,p0122 and a 1765 ? I only get these when i use the switch.
Old Sep 26, 2010 | 10:23 PM
dslfrk's Avatar
double check you tapped the correct wire on the pcu. but i would take the jumper out, put the relay back in and run a 33ohm resistor on the ground side after the switch and that should get rid of codes.
Old Sep 27, 2010 | 08:02 AM
I was just wondering what will the 33ohm resistor do and will i leave the relay in after placing the resistor? The wire i tapped was a orange w/blk tracer on the pcm.Thanks for everybodys help!
Old Sep 27, 2010 | 06:14 PM
dslfrk's Avatar
your throwing a code cause you computer thinks the circute is grounding out. the resistor fakes out the computer into thinking that the computer is locking the converter and doesnt throw codes. You taped the correct wire and yes when you put in the resistor put the relay back in and take out the jumper. This should fix your problems.
ive have a lockup switch for about a year now with no problems or codes.
Old Sep 28, 2010 | 07:36 PM
Ok so i put a 33ohm resistor in from the switch to to my ground source the p0622 and the 1765 code is gone but i still get the p0122 low voltage to the tps sensor? I only get this code when i flip the switch to on.I can then erase the code and it dosnt come back until i flip it to on again? Could this mean my tps is on the fritz.I dont know what they have to do with one another not sure how they work together. When i throw the code it doesnt seem to run any differently?
Old Sep 30, 2010 | 10:40 PM
dslfrk's Avatar
well im glad the resistor worked for the two codes but i dont know why your getting the low voltage code. the only thing i would say to check is that all your connections are good and make sure you plugged the connector to the pcu all the way in. loose or bad connecion will cause low voltage.
Old Oct 1, 2010 | 08:09 AM
I will check all the connections again this weekend and let you know Thanks
Old Oct 9, 2010 | 03:09 PM
I wanted to let you know i got my torque lock switch working just had a bad connection.It works awsome!It was the cheapest upgrade i have done to the truck and probally my favorite one.Thanks again for the help.
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
Cody Cain
Dec 22, 2014 01:27 PM
IslanderXJ
Dec 17, 2014 04:14 PM
