05 6.0 no start when hot
Old Sep 25, 2010 | 10:17 AM
cummin_un_glued's Avatar
FormerVendor
Default 05 6.0 no start when hot
came in with a no start when hot condition...full of oil...good oil pressure...low icp pressure...removed both valve covers and inspected all injector orings found no problems...replaced connecting tubes...no change...replaced ipr...no change...replaced hpop...no change...starts just fine cold and runs fine once it starts but still will not start hot...now what???
Old Sep 25, 2010 | 11:54 AM
12vcummins96's Avatar
do a cylinder contribution test
Old Sep 25, 2010 | 02:54 PM
FormerVendor
it runs perfect once it starts...no miss at all...so i really dont think it is an injector problem...i'm starting to think that maybe it is a cracked branch tube or something
Old Sep 25, 2010 | 02:59 PM
thats very possible are you loosing hpop pressure after it warms up
Old Sep 25, 2010 | 04:58 PM
FormerVendor
yeah that's what its doin and we've checked the injector orings put new connecting tubes in and a new hpop with the new fitting and its still loosing hpop pressure after the engine warms up
Old Sep 26, 2010 | 12:50 PM
Mdub707's Avatar
You said ICP was low, did you change the ICP sensor?
I agree, sounds like a high pressure oil leak. Snap to connect fitting is the most common on these. It's not if, but when it fails kind of deal. Just search for it, pretty common.
Old Sep 26, 2010 | 03:28 PM
biged681985's Avatar
its an 06 not an 05
the new hpop came with the upgraded snap lock fitting thats common to leak.
Old Sep 26, 2010 | 08:01 PM
FormerVendor
sorry ed my bad
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
dandbmcc
Mar 14, 2015 11:05 PM
thumperf350
Jan 8, 2015 12:55 AM
