plugged fuel drain valve/line
Old Sep 23, 2010 | 10:04 PM
goobs's Avatar
Default plugged fuel drain valve/line
i went to change the fuel filter the other day and went to drain out the old fuel but nothing came out when i opened the valve. so i opened it all the way, took the hose off that points to the ground and still nothing. tried to blow through the valve to see if it would make bubbles in the fuel still in the filter housing and nothing is going through.
any ideas guys?
Old Sep 23, 2010 | 10:16 PM
Crazy's Avatar
is the LP working
Old Sep 25, 2010 | 12:19 AM
goobs's Avatar
Originally Posted by Crazy
is the LP working
whats the lp?
Old Sep 25, 2010 | 12:42 AM
gixxertricks's Avatar
compressed air?
Old Sep 25, 2010 | 10:41 AM
Crazy's Avatar
Lift pump
Old Sep 25, 2010 | 07:10 PM
goobs's Avatar
Originally Posted by gixxertricks
compressed air?
i tried that.
Lift pump
yes, its working.
Old Sep 25, 2010 | 09:02 PM
Crazy's Avatar
how clean is the fuel housing
there is screen in it that could be clog
Attached Thumbnails plugged fuel drain valve/line-fuel3.jpg   plugged fuel drain valve/line-fuel2.jpg   plugged fuel drain valve/line-fuel-1.jpg   plugged fuel drain valve/line-fuel4.jpg
Old Sep 25, 2010 | 11:39 PM
Woody35's Avatar
did you actually check it is pumping fuel. just because it makes noise doesnt mean its pumping. i bet your tank sock needs some cleaning.
Old Sep 26, 2010 | 11:41 PM
goobs's Avatar
it was pretty clean, but i couldnt get all the fuel out, so it might have some trach in it.
yes its pumping. the tank has been cleaned and has a new sock, did all that when i took the bed off for the GN hitch.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
