need help about overdrive ground switch
Old Sep 23, 2010 | 07:25 PM
dordboy's Avatar
Default need help about overdrive ground switch
i have a 97 cummins and im trying to get my overdrive to work as well as install a tc lockup switch and when i ground a wire i lose my tack and the light flash on the dash could someone that knows more about this call me please im pulling my hair out!!!
208 880 1132
Zeb thanks
Old Sep 25, 2010 | 08:45 AM
cumminspwr11's Avatar
where did you hook into the trans wires at?
Old Sep 25, 2010 | 03:33 PM
dordboy's Avatar
Right at the the tranny
Old Sep 26, 2010 | 12:28 PM
did you put in the lock up controler or are you just tryin to put them both on toggle switches? also did you leave the wires hooked up to the pcm or disconnect them from there completely?
Old Sep 27, 2010 | 08:25 AM
dordboy's Avatar
just tapted into the wires they are still whole. and both on toggle but i have been fighting with no overdrive this was just a way to try and make it work but i think i might have a bad solenoid. also when i ground the tc wire im dash goes dead but all the start up lights come on
Old Sep 27, 2010 | 12:46 PM
hum that doesnt sound right at all, if your just piggy backing like that then you just need to tap into the correct wire for lock-up and od, run them to two switches and ground the other side of the switches, i have a diagram for the wire connector on the trans i will try and find, so you can make sure you have the right wires
have you checked you fluid and dropped the pan to see if there is any debris in there?
Old Sep 27, 2010 | 03:01 PM
dordboy's Avatar
what wires do you tap as i understand it on my 97 i tap the orange wire and the orange green wire well there are only two orange wires so i tapped the two well hmmm if i could get a phone number of someone that knows a little bit and wouldn't mind hearing me explain i did try a few thangs and nothing is making sense
Old Sep 27, 2010 | 04:36 PM
i wired mine up on my 95 but its a 3 pin 47rh not the 47re like you have, do you have the 8 pin connector on your transmission? pins 6 and 7 are the grounds for od and lock-up, my directions dont say what colors they are tho. but they are right next to each other
Old Sep 27, 2010 | 07:02 PM
dordboy's Avatar
Welli tapt those and neither one are working
Old Aug 19, 2012 | 10:31 PM
parsons_vr6151's Avatar
did u figure out the problem with the overdrive? my overdrive wont work either and i have a new transmission??
