Overheating Problem
Old Sep 23, 2010 | 02:25 PM
GEARHEADPERFORMANCE's Avatar
Default Overheating Problem
I have a 1996 1-ton dually 6.5L turbo with heath diesal GL4 computer, 4 inch exhaust downpipe back. afe intake, Turbomaster wastegate set around 13psi.
When I am pulling my trailer around 5000 pounds the truck will heat up to over 210 degrees, but the egt are only around 800 degrees. Then went a let it idle for a few mins. it cools right back down. And I am not loosing any coolant.
I have a new radiator, water pump, radiator cap, hoses, and a/c condensor.
Any idea's?
Old Sep 23, 2010 | 03:05 PM
tyler111991's Avatar
if the egts dont get very high then i dont see how the motor could be running that hot, i have ran higher egts with a way lower engine temp. have you checked the guage to make sure its not faulty? mine was showing it was running way above 210 just driving around, it turned out to be a problem with the guage... just an idea
Old Sep 23, 2010 | 03:46 PM
Was it the sender or the gauge itself. I was kind of thinking it might be the gauge or sensor because the truck just does not seem hot. It is not throwing any codes when the gauges say it is 235 degree and no coolant is spiting into the overflow.
Old Sep 23, 2010 | 05:11 PM
Woody35's Avatar
did you put in new ac delco thermostats
Old Sep 23, 2010 | 09:06 PM
Crazy's Avatar
X 2 on thermostats
how about clutch fan kicking in
Old Sep 24, 2010 | 01:31 AM
it was the sending unit. and if it were running 235 degrees im sure it would be over flowing coolant
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
swartile
May 8, 2015 01:03 PM
thurobred1320
May 5, 2015 09:26 PM
