FICM failures?
Old Sep 23, 2010 | 08:58 AM
doin my own 6.0's Avatar
Default FICM failures?
Ok: so now that I have verified that my FICM is faulty, what causes these things to just suddenly go bad? I've heard some stories about voltage surges from a failing alternater to bad batterys, others have said that they are like light bulbs.... good one second bad the next? I just got my new autoenginuity scanning diagnostic program, and that was the first code to pop up. I had three codes. p6011- ficm, p1000- computer test incomplete, I forget the whole code for the last but it was a low turbo boost.? I can have my ficm repaired but what will keep it safe from happening again? is it poor construction, heat and vibration ? when I have it repaired I'll have the option of increasing the output voltage to the injectors, does the increase make the injectors more efficient in their operation? or will it cause the injectors to run alittle hotter? any input would greatly appriciated, I'm gonna pull it out tonight.
Old Sep 23, 2010 | 03:01 PM
MUDSTROKIN''s Avatar
Call Swamps diesel and talk to Dave Armstrong. He will Set you up with an FICM that is built stronger than the factory one. And you can up the voltage to 58V if you choose to. the stock ones fail because the solder joints are weak and fail because they split apart and loose voltage flow
Old Sep 23, 2010 | 03:53 PM
Lange503's Avatar
what kind of gains do you see from changing to the 58V?
Old Sep 23, 2010 | 03:55 PM
I've never seen dyno sheets for it, but i hear it's a 40 HP gain. The 48v is perfectly fine too just doesn't give you any extra power....
Old Sep 23, 2010 | 04:15 PM
Lange503's Avatar
extra power is always nice ha
Old Sep 24, 2010 | 09:35 AM
Do you have a number for Swamps diesel. I was thinking about sending it to the board medic's . I will probably do the resolder my self, but the increase in voltage looks pretty nice ?? the cost is about 300$ give or take.. we'll see. any sources to get the silicone boot's for the intake tubes, I pulled my truck down last night, and removed the intake tubes just to clean things up while I had it apart and I found that I have another boot going away, these are ford pieces the second set in a 100k, I think I would like to try another brand? any ideas ?
Old Sep 24, 2010 | 11:58 AM
Lange503's Avatar
BD power has a decent boot set up for them, try them out and see what you think
Old Sep 27, 2010 | 08:44 AM
thanks I saw them this weekend I was on line looking around, the price seems comparable.
Old Sep 27, 2010 | 12:09 PM
Swamp's Diesel Performance
304-A Sand Hill Rd.
LaVergne, TN 37086
office# 615-793-5573
fax# 615-793-5572
email- dave@swampsdiesel.com
And i would recommend doing the CCV Mod and you won't have this problem anymore.
Old Sep 28, 2010 | 02:07 PM
thanks I'll give them a call. what is the CCV mod?
