Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
05 Duramax 2000 rpm shut off
Old Sep 23, 2010 | 07:13 AM
JFOST's Avatar
Default 05 Duramax 2000 rpm shut off
a buddy of mine has a 05 Duramax and every now and then it will get to 2000 rpm and just shut down. it has fuel power and acts normal until it hits the 2000 rpm wall. he has changed fuel filter, and still does it. it also has wont start on occasion. Every body just keeps telling him fuel filter. the truck just hit 100k miles and is a allison auto 4x4. Any body have this problem or have any ideas i could give him?
Old Sep 23, 2010 | 07:41 PM
2500HeavyDuty's Avatar
is there any codes? what mods does he have done to the truck
Old Sep 25, 2010 | 01:20 PM
Rood41x's Avatar
My 04.5 LLY did the same thing and came up with P1093 low fuel rail pressure during power regiment (sp). When this happens, I know that the ECM goes into fail safe mode and limits the speed to exactly 65 mph and wont allow the motor to turn more then 2000 rmps. The ecm will do this for several different codes though, so it would really help to have the codes if the check engine light comes on.
Old Oct 23, 2010 | 02:05 PM
JFOST's Avatar
He has a bully dog power pup and a 5" exhaust and k&n intake. He is not getting any lights and so he hasnt checked for codes ?
Old Oct 23, 2010 | 03:50 PM
jbrown1132's Avatar
i'm not sure if the pup can show any codes, if not, have him go by a parts store like napa or autozone and borrow a code reader to check for codes. then repost with codes found.
without this info, its like hunting for a needle in a hay stack
Old Oct 23, 2010 | 03:52 PM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Put a fuel pressure relief blocker in it. Issue solved.
Old Oct 24, 2010 | 03:25 PM
JFOST's Avatar
He ran it on scanner today and it showed like a no flow egr?
P0401. Insufficient egr flow detected
Old Oct 24, 2010 | 03:49 PM
bobcat67's Avatar
yeah sounds like the EGR is clogged/plugged up with soot, I believe there are deletes or "plugs" that make is so the EGR doesn't work which is a beneficial thing rather than a bad thing, probably gonna need to switch tuners though, Bullydog isn't the greatest, they are OK but i'd be tempted to go with a PPE or an EFI live setup of some sort
Old Oct 28, 2010 | 03:30 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Yes there are plenty of people who make an EGR delete kit. They are DEFINATELY one of the first thing you should do to an LLY especially a modded one. It recirculates soot back into your intake manifold making quite an ugly mess, especially if the PCV has not been relocated also.
Old Oct 30, 2010 | 10:51 PM
duramaxfarmboy's Avatar
have him get a kennedy finger stick and egr blocker plate its like 55 bucks just type it in to google and hell find it
camp9
Mar 25, 2017 07:40 AM
cgraham
Aug 4, 2015 07:50 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
duramaxtuner
Dec 10, 2014 01:24 PM
Oct 30, 2014 08:10 AM
