Remote Keyless Entry (RKE) Programming Help
Old Sep 22, 2010 | 03:41 PM
01ctd's Avatar
Default Remote Keyless Entry (RKE) Programming Help
Hello,
Need to program a spare Key fab for 01 CTD, I tried the online methods with no success.
I can get the truck to reprogram mode but my spare will not program. I had the dealer test the key fab, battery and signal are strong per dealer. Just need a little help without taking my truck to the dealer.
thanks
HD
Old Sep 22, 2010 | 04:05 PM
RAW's Avatar
RAW
Programming Additional Transmitters
Up to four transmitters can be programmed. When programming a new transmitter, all transmitters intended for use with this vehicle, except the transmitter used to start the programming mode, must be programmed within the 30-second programming mode. To program a transmitter, turn the ignition switch to the ON position with the vehicle stopped. Press and hold the unlock button on a currentlt programmed transmitter for a minimum of four seconds and a maximum of ten seconds. While pressing the unlock buttor, press and release the panic button. Release the unlock button and a single chime will sound. This indicates that the module is in programming mode. Within thirty seconds, press and release the lock or unlock button on all transmitters intended for use with this vehicle except the transmitter used to start the programming mode. Successful programming will be indicated by a single chime.
I was ale to find this, is this the procedure you are using?
Seems to be a few different methods;
http://dodgeram.info/tsb/2002/08-007-02.htm
Old Sep 22, 2010 | 04:09 PM
01trailerpuller's Avatar
I have a copy of the reprogramming instructions. If you send me a PM with your email in it I will scan it and give you a copy. But You need to have at least one working fab to do it with the instructions I have.
TSB 08-007-02
This is very similar to the one that I have.
Last edited by 01trailerpuller; Sep 22, 2010 at 04:09 PM. Reason: Automerged Doublepost
Old Sep 22, 2010 | 04:29 PM
01ctd's Avatar
different reprogram methods from the original manual, here's some of the website: filear.com, TSB 08-007-02. I tried them all, i'm using a working keyfab to force the truck to program mode.
Old Sep 22, 2010 | 06:58 PM
If you still want that instruction sheet give me a PM and as soon as I get back home I will send it to you.
Email sent.
Last edited by 01trailerpuller; Sep 22, 2010 at 06:58 PM. Reason: Automerged Doublepost
Old Sep 26, 2010 | 12:36 PM
Captain Call's Avatar
Get gone spam boy!
Looks like he was fried like the spam he was.
Last edited by Captain Call; Sep 26, 2010 at 12:36 PM. Reason: Automerged Doublepost
Old Sep 26, 2010 | 11:35 PM
There was no spam about it. I have a copy of all of the dodge 96-06 programming instructions for the key fab. Would you like a copy? Plus dude you know me!
Old Sep 26, 2010 | 11:40 PM
haha, yeah......nothing to do with you bud. Where are you these days? I'm south till tomorrow then back home to Ut.
Old Sep 26, 2010 | 11:52 PM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
