24 Volt system
Old Sep 21, 2010 | 10:05 PM
Sandman8105's Avatar
Default 24 Volt system
The hinge pins were a pain in the a$$! But, I finally got them with a little help from a preacher. I am getting a warn 18,000 lb winch for the old girl but, it requires a 24 volt system. Can I set that up with the batts. that I have or, do I need to get two more to set it up?
Crawler or anyone else have any idea's? I am trying to set this up for the winch ONLY!
Last edited by Sandman8105; Sep 21, 2010 at 10:05 PM. Reason: Automerged Doublepost
Old Sep 22, 2010 | 10:19 AM
DieselCrawler's Avatar
i will search some tommarow. u will need an isolator i belive.
what winch is it. u said warn 18000 lb, what model? might be easier to contact warn and see if they have a 12 motor for it? any starter/alternator repair shops around you? i have one near me that rebuilt the motor for my warn xd900i for 200 bucks. wunder if they could conver the motor to 12 volt?
Don's Alternator Generator Starter Service of Orange, Orange, TX : Reviews and maps - Yahoo! Local
not sure how far u are from here.
Last edited by DieselCrawler; Sep 22, 2010 at 10:31 AM. Reason: Automerged Doublepost
Old Sep 23, 2010 | 04:21 AM
about an hour. so, i need a dual battery isolator?
it is a warn industrial 18. (18,000 lb.) Got it for $650.00 new.
Last edited by Sandman8105; Sep 23, 2010 at 04:21 AM. Reason: Automerged Doublepost
Old Sep 23, 2010 | 06:19 AM
if it can be converted to 12volt, no.
Old Sep 25, 2010 | 03:00 AM
Thanks Crawler. I think that it can be done but, it would cost a lawn dart in the a**.
Old Sep 25, 2010 | 07:16 AM
for the price u got that winch for, u can spend some on a motor. that winch new is 1800
Old Sep 25, 2010 | 09:41 AM
RAW's Avatar
RAW
You could easily add another battery in series, creating 24volts, then run only the winch off the 24 volt battery. The only thing I am unsure of is if the 12volt battery, and alternator, will properly charge the second battery. I like this idea as the 24 volt motor would be nicer to have. I may experiment with this at the shop later today.
Old Sep 25, 2010 | 08:53 PM
Hyde's Avatar
24v is easy to setup with two 12v batts, problem is a "dead" 24v system is still at more of a charge than a fresh 12v system. That means the 24v system would have to be completely isolated from the 12v system. You would have to find a 24v alternator, if you are handy you could probably make a bracket and use a 24v alt off of some kind of heavy equipment on it. Easiest place would be where your AC is if you have it but seeing as you are in TX thats probably something to keep.
Old Sep 27, 2010 | 01:44 AM
Definately have to keep the a/c. I'm just trying to go about this the best way but, more importantly, do it right; the FIRST time! Thanks everyone. Please keep the expert information comming. I need all the help with this that I can get.
RAWilliams,
Let me know what you find out please. Now you've got me curious........
Last edited by Sandman8105; Sep 27, 2010 at 01:44 AM. Reason: Automerged Doublepost
Old Sep 27, 2010 | 02:01 AM
Hyde's Avatar
The 12v system wont keep the 24v charged. Hooking it into your 12v system at all wouldnt be good. By the way, ambulance packages had dual alternators. Not sure where the second alt was mounted but it might be worth looking into. From there im sure you could fab a way to put a 24v alt in its position.
