Cab lights
Old Sep 21, 2010 | 03:03 PM
RandoH's Avatar
Default Cab lights
Ok guys so I have a 2000 and want to install cab lights, it doesnt look that hard just time consuming. Anyone have any reccomendations? I have heard good and bad on Recon etc just dont want to have to do this more than once any tips or reccomendations would be great thanks
Old Sep 21, 2010 | 03:55 PM
orcutt32's Avatar
all you have to do is drill the holes evenly spaced the hard part is wireing them up
Old Sep 23, 2010 | 01:28 AM
01trailerpuller's Avatar
There is an even easier way to do it drop your head liner there are supports that show where the cab lights should go. Use a center punch in the center of each one as a drill point. Then drill from the inside out. Once you have the hole drilled line up where you want the lights on top and mark the screw holes. then drill those holes and screw them in. Once you have them in wire them up put back in your head liner and you are done. The first time I did it it took me about 3 hours by myself the second time on my buddies truck with his help it to 1.5 hours.
crashmarvin
Jun 15, 2015 07:10 PM
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
