Oil leak 95 12 valve
Old Sep 21, 2010 | 02:11 PM
jbuck's Avatar
Default Oil leak 95 12 valve
Recently had tappet cover replaced due to major oil leak. The valve cover gasket are leaking oil now. Is this due to the crank case not being able to vent through the old leak location anymore. Am i getting more pressure being built up under the valve covers. I removed the covers and the gasket looks fine. I do not seee any leaks under idle. Any thought?
Old Sep 23, 2010 | 01:15 PM
Dirt_Diver's Avatar
I had the same trouble too! I added some valve breathers on mine and it seems to help out! If you wanna see a pic, i can upload a pic or too for you.
Did you check the vent on the tappet cover and see if its clogged?
Old Sep 23, 2010 | 11:13 PM
jbuck's Avatar
Default Oil leak
yes pictures would be great, thanks.
Old Sep 25, 2010 | 10:34 PM
Dirt_Diver's Avatar
Here you go!!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Sep 25, 2010 | 11:47 PM
wadef1994's Avatar
how come cylinder five is alot dirtier?
nevermind i see its an oiled one
Old Sep 26, 2010 | 12:12 AM
FastCR's Avatar
nice! I only used 1 and solved my problems for the most part. after replacing the tappet cover and valve cover gaskets
Old Sep 26, 2010 | 11:24 AM
Dirt_Diver's Avatar
The reason #5 is alot dirtier, its a different filter because the orange steel mess ones were discontinue and i bought the rest that they had. So the next best choice was that one!
I thought it woiuldve looked cooler, but the hardest part for me was trien to get all the holes aligned the same!
Old Sep 27, 2010 | 12:29 PM
jbuck's Avatar
Thanks for the input and pictures. That worked no leaks.
cummins Pride
Sep 28, 2015 12:11 PM
Jake12valve
May 10, 2015 11:57 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
