83 6.2 gauge cluster
Old Sep 20, 2010 | 12:11 PM
jdurb58's Avatar
Default 83 6.2 gauge cluster
Hey everyone, I'm new to the site, but not to the game, anyways. I inherited an old 83 c-10 with 6.2 in it. It had sat for over 10 years before i got it. Well i finally got it running, and it actually runs pretty good. Only problem i have is with the stock gauges in the dash. the volt meter, oil psi, and temp are inop, and the fuel gauge does whatever it wants. the fuel gauge, i'm not too concerned with for now, but does anyone know if the three other gauges share a common ground, or common fuse somewhere? i've checked the fuse block, and i don't see one that says anything about instrument panel? any ideas?
Old Sep 20, 2010 | 08:14 PM
Woody35's Avatar
i would clean all the grounds personally. i cant imagine all the corrosion and rust bulit up after sitting ten years
Old Sep 20, 2010 | 08:16 PM
wildbill's Avatar
Have to remove the entire cluster from the dash. There is a printed circuit ribbon that needs the contacts cleaned. Been there on few older GM trucks.
Old Sep 21, 2010 | 05:07 PM
jdurb58's Avatar
cool, thanks guys. I'll look at pullin the dash out tomorrow
Well I pulled the cluster out today, the ribbon looks to be in good shape, I do not see any corrosion, rust or cuts, tears. Not real sure where to go from here, I guess I could just put a set of manual gauges in it and be done, but I'd rather have it all working properly.
Old Sep 25, 2010 | 03:43 PM
jdurb58's Avatar
well, i decided not to mess with it, bought a set of manual gauges and put them in the dash cluster in place of the stock gauges. looks real good, almost factory. but i need help finding sending units on the engine, where is the oil psi and coolant temp sending units on these?
Powerstroke36
Sep 21, 2015 08:32 PM
gauge1325
May 3, 2015 01:33 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
Ibanimal
Oct 31, 2014 09:07 AM
