Bad injector pump timing? starts hard and blows blue and withe smoke when cold
Old Sep 20, 2010 | 02:11 AM
builtFORDtough22's Avatar
Default Bad injector pump timing? starts hard and blows blue and withe smoke when cold
hey i have a 1990 F250 with a 7.3 international IDI and it starts hard when it sits overnight and blows blue and white smoke till she warms up. Wondering if it might be bad injector pump timing? i would appreciate any ideas. Thanks
Old Sep 20, 2010 | 01:43 PM
DieselCrawler's Avatar
how many miles on it?
Old Sep 20, 2010 | 07:04 PM
Sycostang67's Avatar
Sounds more like bad glow plugs to me.
Old Sep 20, 2010 | 09:57 PM
I just bought it a few weeks ago and the guy I bought it from used it around a farm and told me it has 106 thousand on it but who knows if that is true it could be 206 thousand... i put an etg in it and turned up the injector pump about 2 flats and made an air intake for it and put stacks on it but it blew the blue and white smoke before I did all of that... it does is for 30 to 45 seconds or so on cold start then it seems fine
And when she fires up it runs rough till it warms up almost like its misfiring
Last edited by builtFORDtough22; Sep 20, 2010 at 09:57 PM. Reason: Automerged Doublepost
Old Sep 20, 2010 | 10:06 PM
could be an injector. is the ip stock?
Old Sep 20, 2010 | 11:21 PM
i believe it is stock
Old Sep 21, 2010 | 06:24 AM
i am gona say pump and injectors are probly starting to wear. normal life for ip and injectors is 100000 miles or so.
Old Sep 21, 2010 | 11:39 AM
what is a good brand to buy that is somewhat affordable?
Old Sep 21, 2010 | 05:35 PM
any reputable pump shop. lookin around 500-700 for a good pump.
300-400 for good injectors. make sure injectors get pressure matched and after all done the pump gets properly timed.
where are you located? also fill out all your info in your sig so we know what u got.
Old Sep 22, 2010 | 03:59 PM
mankato minnesota is where im located and im not sure how to fill out the info haha ill see if i can figure it out
is that something like you want to see?
Last edited by builtFORDtough22; Sep 22, 2010 at 03:59 PM. Reason: Automerged Doublepost
