hard starting
Old Sep 19, 2010 | 08:38 PM
wisconsin redneck's Avatar
Default hard starting
sooo this is kinda starting to **** me off. i have been trying to fix this for a month or 2... when my truck sits for 4 hours or more, it pops, and smokes white like crazy and runs rough for a minute, then after that it runs fine. i have replaced the ofv, every single inch of fuel line (pressure and return) in the truck. the injectors seem to be leaking a little bit, not much tho. thats next on my list. would that be the problem?
Old Sep 20, 2010 | 11:45 AM
goalie990's Avatar
id bet its the injectors leaking into the cylinder when you let it sit.
Old Sep 20, 2010 | 02:46 PM
Dallas Flywheels's Avatar
Fuel leaking back,and or sucking air some place.
Old Sep 20, 2010 | 04:11 PM
Bubba88's Avatar
x2
Old Sep 20, 2010 | 04:49 PM
gixxertricks's Avatar
Originally Posted by Bubba88
x2
sounds logical
Old Sep 20, 2010 | 04:51 PM
Farmboy 2.0's Avatar
Sounds like injectors loosing pressure
Old Sep 20, 2010 | 06:53 PM
ok sooo im gonna go with injectors... my mechanic that used to work on my truck said he pop-tested them... which was about 4 months ago. but he also said he fixed my fuel leak... which wasnt true, so to fix this injector problem.... what has to be done?
new injectors? seals?
Old Sep 20, 2010 | 10:58 PM
lodal cummins's Avatar
pull the injectors and take a mini shop vac with small hose and suck everything out of the injector holes. that will make sure there is nothing in between the copper washers. that is what i did and there was a bit of crap in the holes. no leaks at all. just my 2 cents!
Old Sep 21, 2010 | 11:52 AM
well i just ordered a set of sdx's last night, just 5X.10s so nothin to big cant wait for them to get here!!!
Old Sep 27, 2010 | 12:04 PM
Bubba88's Avatar
those are great injectors....im gettin a set of 5x.16 when i get the twins
Excursion73
Oct 27, 2015 05:21 PM
Easton18t
Jul 30, 2015 02:06 PM
joker55
May 15, 2015 10:24 AM
gwmeyer
May 14, 2015 12:46 PM
91 7three
Jan 7, 2015 09:37 AM
