white smoke
Old Sep 18, 2010 | 07:01 PM
csdiesel's Avatar
Default white smoke
my powerstroke has 106667 miles on it, at 100k i deleted the egr . i am running 10-30 and rev x. in 50 degree wether i get alot of white smoke on start up, where ever i go there is always the eye watering smell of fuel and the diels shop here in town tells me there is nothing wrong with it, any help would be appriciated
Old Sep 20, 2010 | 07:12 PM
newman's Avatar
Sounds like a bad injector to me. DO you have access to a scan tool to do a contribution test?
Old Sep 20, 2010 | 09:47 PM
csdiesel's Avatar
i can get ahold of a snapon lotus. if that will work, what is the procedure for that contribution test?
Old Sep 21, 2010 | 07:12 PM
newman's Avatar
If it will work on a 6.0 it will be an option on the menu under KOER(Key On Engine Running)
Old Sep 21, 2010 | 08:10 PM
csdiesel's Avatar
thank you, ive been told buy ford, black cloud diesel and rapid diesel, to use 10-30. now im told to use synthetic 5-30, i tought it was a truck not a honda.
Old Sep 21, 2010 | 08:23 PM
Mdub707's Avatar
What 10-30? Make sure it's diesel oil! I use 15-40 and have used both synthetic and non. There is supposed to be some good 5w-40 synthetic diesel oil out now too. I wouldn't use 10-30 gas oil....
Sounds like a sticky injector to me too. Does it clear up once it's warmed up?
Old Sep 23, 2010 | 07:06 PM
csdiesel's Avatar
way a headof you. i just put rotella 5-40 sythetic in and my white smoke is gone.
****, i lied still white smoke, and the morons at ford did a cylinder cut out test instead of a contribution test.
Old Sep 23, 2010 | 10:22 PM
gloplugz's Avatar
theres a feature that allows you to disable injectors 1 at a time. you will feel when a cylinder misfires.usually a lowcircuit code will pop up on KOER program.
Old Sep 26, 2010 | 10:58 AM
csdiesel's Avatar
i was thinkin with no egr can i get a tuner with an egr delete tune?
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
