big intercooler. and maybe p pump
Old Sep 18, 2010 | 03:15 AM
Muddyswampdonkey's Avatar
Default big intercooler. and maybe p pump
ok will a 99 dodge intercooler fit Without hacking my rad support appart?
i know about the powerstroke cooler and that was the original plan but
a 100 psi spearco is for slae local here out a wrecked 99.I can get it for aroung $600
not sure the fit though..
will go great with the he351 i just got
Old Sep 19, 2010 | 12:40 PM
seandonato73's Avatar
i have a stock 24v intercooler layen here at home and it dont look good for it fitting in a first gen.
Old Oct 30, 2010 | 07:12 AM
Rusty89Cummins's Avatar
ya you can do it but you are going to have to cut out some metal. and if you have a ac cooler it will be an even tighter fit. heres my write up on when i did it.
installed intercooler on my '89 - Dodge Cummins Diesel Forum
Old Oct 30, 2010 | 08:58 AM
RSWORDS's Avatar
Is this going in a dodge or a the ford in your sig? I woudl not spend $600 on a used intercooler when you can get a 7.3 for around $100-$150. Also the Spearco is not gonna be teh same dimensions as the stock 24v intercooler, sure it will "drop in" but the overall dimensions are bigger. seeing as how the stock 24v is a tight fit I would not want to risk it not fitting.
Old Nov 9, 2010 | 04:20 PM
1STGENFARMBOY's Avatar
I hope by p pump your talkin about a piston lift pump and not a p-7100. this is afterall a rotory bombs section.
Dar
Old Nov 14, 2010 | 09:31 PM
FIRST GEN. JAKE's Avatar
call me a traitor but im swaping to p pump this winter haha
