Shifting problem =/
Old Sep 17, 2010 | 06:07 PM
Dude_57's Avatar
Default Shifting problem =/
Ok so at first awhile back my truk was having shifting problems it would downshift twice while going about 55 or so and it was my tps sensor that went out well a year or so later which is now it di it again but I I figured out that I knocked the adjustment arm off so I adjusted it and it's fixed but now when I'm going like 45 to 50 and let off the gas but not completely every once in awhile I will keep downshiftin anyone have any idea?? And also is it possible at all to change how my transmission shifts?? And what exactly controls the transmission and tells it when to shift? I just ordered a new transmission and it will be put in Monday unless another delay comes up but you think that putting a new one in might fix it? Thanks guys!
Old Sep 17, 2010 | 06:33 PM
bowtech's Avatar
you just need a valve body to fix it
Old Sep 17, 2010 | 06:38 PM
Dude_57's Avatar
Oh??? Well I'm getting a fully built goerend tranny put in what exactly does the valve body do if you don't mind me asking and thank you =)
Old Sep 17, 2010 | 06:50 PM
Farmboy 2.0's Avatar
The valve body controls the pressures for the shift points
Old Sep 18, 2010 | 01:58 PM
bowtech's Avatar
ya the vb is the brain of the tranni its what controls the shift points
Old Sep 23, 2010 | 07:19 PM
Dude_57's Avatar
Ok so I replaced the tranny and I can't tell if it's doing it every once in awhile or not.... I'll speed up and get to like 65 or so let off and wait til about 50 or so and and step back on the gas and instead of shifting it keeps the rpms up for a a couple seconds then shifts instead of right away I was told to let the new tranny get all lubed up and everything for a few days then check back
Old Sep 24, 2010 | 06:53 AM
Drothgeb's Avatar
I've got a new, fully built Goerend's in my truck too. It's a great trans but, some info got mis-communicated along the way and it didn't come with shifting setup I expected. So, just because it's a Goerends, it doesn't mean the setup is the best for your truck.
In my case, I talked to Dave, and they sent some different springs and explained how to adjust the VB to get the setup I wanted. Yours may require adjustments too.
Overdrive and TC locking are controlled by the TPS. If they happen too low, you need an adjustment or replacement. The TV cable along with line pressure will effect your full throttle shifting. If you can't get it high enough with the cable, then you need stronger springs or shims in the VB. There is also an adjustment on the VB for low speed shifting. My trans required all of the above, so yours might too.
Old Sep 24, 2010 | 07:05 AM
Dude_57's Avatar
Everything shifts amazing though right on the dot perfect just when I cruise to about 40-45 it wants to keep downshifting..... I just found that sweet spot this morning while driving. Someone also told me to check my throttle cable and stuff
Old Sep 28, 2010 | 03:05 AM
smokedout's Avatar
all it is is your tps!
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
SixSpeed
Jan 11, 2015 01:41 AM
Oct 14, 2014 03:30 PM
