99 issue oil leak
Old Sep 17, 2010 | 04:19 PM
RandoH's Avatar
Default 99 issue oil leak
Hey guys so here goes I dont have much info here its a friends truck, 99 completely stock noticed bad fuel mileage and loss of power, says it seems to be really wet on the air intake side likely oil any ideas where to start? I havent looked at it yet to see or even begin any ideas would be appreciated!
Old Sep 17, 2010 | 06:06 PM
Dirt_Diver's Avatar
Maybe a blown turbo seal? Look inside the turbo and also check your return line that goes from the bottom of the turbo to the block.
Old Sep 19, 2010 | 09:26 PM
dslfrk's Avatar
sounds like a turbo seal to me too. and for the power maybe the turbo has too much shaft play and thats causing low boost from slop and also what took out the seal.
Old Sep 20, 2010 | 03:30 PM
RandoH's Avatar
Thanks for the help guys at least thats a starting point
Old Sep 27, 2010 | 10:09 PM
David411's Avatar
Turbo seal, could check oil filter seal too.
Old Sep 27, 2010 | 10:32 PM
Dirt_Diver's Avatar
So have you found a verdict yet? If its your turbo seal. i got a used turbo if you interested.
Old Sep 29, 2010 | 02:24 PM
RandoH's Avatar
nothing yet, talked to him last night now it wont shift out of 2nd he thinks, reverse is ok, wont shift into lower or higher gear though.... so starting on that one now
cummins Pride
Sep 28, 2015 12:11 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
powerstroke4178
Nov 27, 2014 02:35 PM
