Nv 4500 or 5600
Old Sep 17, 2010 | 08:06 AM
Heavy Smoker's Avatar
Default Nv 4500 or 5600
What is reccomended if I do an auto to manual swap on my 98 cummins. Im planning on making 500hp but no more. The nv 4500 or the nv 5600? I'd rather spend less and the 4500 is significantly less pricey.
Old Sep 17, 2010 | 10:23 AM
94 12valve's Avatar
IMO go with the 4500
Old Sep 18, 2010 | 12:12 PM
dan33klein's Avatar
4500, cheaper, lighter, easier to get parts for
Old Sep 20, 2010 | 06:21 PM
ok thanks
Old Sep 20, 2010 | 07:08 PM
NV4500HD is a lot more fun to drive if you have some power.
NV5600 is much more suited to towing.
Old Sep 20, 2010 | 07:16 PM
Jet A Fuel's Avatar
As far as the transmission go they are both the same ratio at the 5th gear(NV4500) and the 6th Gear (NV5600) so top end ratio is the same.
The NV5600 has a 13" flywheel which is good.
You can install a 13" conversion on the NV4500.(which is what I did)
The NV4500 has a weak link at the fifth gear nut on the output shaft. The early nuts have been known to back off and cause the loss of fifth gear.
The fix for this is a later style nut which is split and allen keyed, some people with extreme care have tack welded the old nuts with some success.
There is a full spline output shaft available which in my opinion helps give the 5th gear a better surface to load on therefore less wear at the spline.
If you buy a junkyard trans get the shifter console and boots,clutch mechanism,put yourself a good HD Clutch Master cylinder and slave unit the clutch suitable up to your required HP.
IMO the NV4500 is a great trans and like you said parts are more readily available.I have pulled my 13,000 lb 5th wheel all over the country and these were some of the issues I encountered.
I hope this little bit off info helps you out.
Old Sep 27, 2010 | 08:01 AM
What do these 4500's usually come out of? Delivery vans ups trucks?
Ill have to go to the junkyard to see if i can find one.
Last edited by Heavy Smoker; Sep 27, 2010 at 08:01 AM. Reason: Automerged Doublepost
Old Sep 28, 2010 | 06:27 PM
monster12valve's Avatar
contact bosleys up in pa.. they sell a full swap for our trucks. $2100 i believe or pm blackcloud he did a swap from them and i think he was happy with it
