Have A Gasser Problem? Where To Look
Old Oct 24, 2007 | 09:02 PM
dmaxjenn's Avatar
IT'S A GIRL!
Default Have A Gasser Problem? Where To Look
Codes 12 and 22 are coming up on the pilot truck, says service engine soon. where can i get the codes from.?
Its a 93 350.chevy sb.
Old Oct 24, 2007 | 09:07 PM
Benjamin's Avatar
Bombardier
http://autorepair.about.com/library/...l-dtcs-33a.htm
12 don't worry....
22 Throttle Position Sensor Signal Voltage Low
Whit's Avatar
Site Mascot
right here
https://www.dieselbombers.com/codes.php
Old Oct 24, 2007 | 09:13 PM
Benjamin's Avatar
Bombardier
Originally Posted by Whitmore
that's for OBDII Hoss.....
Old Oct 24, 2007 | 09:16 PM
Whit's Avatar
Site Mascot
OK..so that wont work eh hoser????
Old Oct 24, 2007 | 09:48 PM
dmaxjenn's Avatar
IT'S A GIRL!
throttle postion sensor? so what. let it warm up before i leave?
just started this last three trips........nothing to worry about i guess....??
Old Oct 24, 2007 | 09:49 PM
Whit's Avatar
Site Mascot
is the truck working fine???
so you have codes but no problems???
Old Oct 24, 2007 | 09:53 PM
dmaxjenn's Avatar
IT'S A GIRL!
so far the trucks running fine. changed the oil last week and filter, just the check engine light came on so I did a code check and thats what it came up as..
Old Oct 24, 2007 | 09:55 PM
Benjamin's Avatar
Bombardier
http://www.autozone.com/selectedZip,.../selectZip.htm
~25 bux to replace yourself.... it'll cause poor fuel economy.... that in turn can cause fouled O2 sensor, clogged cats, bad sparkplugs from running either lean or rich..... it's better to replace it and be done with it.....
Old Oct 24, 2007 | 09:56 PM
Whit's Avatar
Site Mascot
I wouldnt worry bot it then but you can try this......wont hurt nuttin
turn key on but dont stsrt
push peddle slowle all the way to the floor
let pedel up slowly
turn key off
start truck
you just reset it...................I think
