no overdrive any suggestions ??
Old Sep 15, 2010 | 07:44 PM
dordboy's Avatar
Default no overdrive any suggestions ??
Hey I have a 1997 cummins and the overfrive won't kick in any ideas???
Old Sep 16, 2010 | 12:53 AM
blazier18's Avatar
could be your tps (throttle position sensor) just an idea
Old Sep 16, 2010 | 06:36 PM
Heavy Smoker's Avatar
Its most likely the vss located on the end of the tranny.
Old Sep 16, 2010 | 07:31 PM
jrad989's Avatar
tps. search "tps" and you will find everything you need.
Old Sep 17, 2010 | 09:20 AM
Dallas Flywheels's Avatar
My 1996 did the same thing. Replaced T.P.S. end of promlem
Old Sep 17, 2010 | 09:55 AM
dordboy's Avatar
Ill check it out guys thanks for the help!!!!
Old Sep 21, 2010 | 10:04 AM
dordboy's Avatar
ok cleaned and checked tps seams to be working fine. and this is kicking my but i it shifts fine through all other gears and has plenty of power (no slipping). i know it could be the shift solenoid is there a way to test that as well???
Old Sep 21, 2010 | 03:05 PM
lodal cummins's Avatar
knock the set pins out and drill the holes out bigger on tps then rotate it counter clockwise to increase voltage. what voltage are you getting at wide open throttle? then i would check shift solenoids.
FF131
9
Mar 26, 2015 07:06 AM
billy-bob
5.9L 12V Performance
Jan 23, 2015 08:48 PM
thetrot
Jan 15, 2015 09:51 PM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
Dunn
99-03 7.3L Performance
Oct 26, 2014 01:44 PM
