not a chevy guy
Old Sep 15, 2010 | 12:43 PM
cornfed's Avatar
Default not a chevy guy
Im not a chevy guy at all but Im trien to help a freind so please be patient with me. It is a 94 chevy, it has been sitting for awhile, and the guy he bought it from said he was driving down the road and it just died, he gave up on it. what I need to know is where do I start are there any common problems with these trucks that might be the problem here or do I just need to do basic checks of everything. I have already sugested a new set of bateries to make sure the voltige is up before we do anything else. just need some advice dont have alot of time at home and I dont want to waste time if I dont have to sorry I dont have any mmore info on the truck, If you guys need I will do my best to get it. thanks in advance for all your help.
Old Sep 15, 2010 | 02:33 PM
FastCR's Avatar
See if it'll run now. someone correct me if 94 wasn't the first DS pump year.
Theres a black module mounted on the side of the pump called the PMD. A design flaw is that it gets too hot and craps out. It controls the pump. Google PMD relocation. If it does start then starts running shitty or dies, dump ice water on it and see if it runs again.
Old Sep 15, 2010 | 08:26 PM
cornfed's Avatar
sounds like a good start I will give it a shot and see what happens thanx.
Old Sep 15, 2010 | 09:05 PM
Woody35's Avatar
dont get the ss diesel pmd relocation kit. it just moves the pmd on the intake where it will crap out faster due to heat rising. pmds on the pump die because they get heat soaked when the engine is off. when it is on its cooled by diesel fuel in the pump. relocate the pmd to behind the front bumper gets good cooling there. pmdcable.com is a good place to find it.
Old Sep 15, 2010 | 09:27 PM
cornfed's Avatar
thanx for the info Im more convinced that the PMD is the problem but is there a way to check it and make sure?
Old Sep 15, 2010 | 09:55 PM
Woody35's Avatar
get a confirmed good pmd and hook it up. those used pmds on ebay are a gamble fyi if your looking for a cheap route. better just to get a new dtech
Old Sep 15, 2010 | 10:17 PM
cornfed's Avatar
ok i will check it out in the am thanks for helpin out a ford guy
Old Sep 15, 2010 | 10:57 PM
Woody35's Avatar
no problem
Old Sep 21, 2010 | 11:59 AM
cornfed's Avatar
ok so do you haved to pull the intake to get to the pmd
Old Sep 21, 2010 | 06:54 PM
Woody35's Avatar
if you have small fingers and are good with a dental pick you dont have to remove it but its extremley hard to get it unplugged without doing it. i did it besides it gave me a chance to clean all the carbo buildup that had accumalated after 13 years.
