Give me a hand with this.........
Old Sep 14, 2010 | 09:36 PM
big bad diesel 416's Avatar
Site Sponsor
Default Give me a hand with this.........
So driving down the road at 70 MPH 2500 RPM my stock gauges and radio start to flicker and freak out and bam dead no power got to where I needed to go and it would not **** off unless I push the E-Brake and would not start after that (with the key) no headlights blinkers or brake lights all after market works and radio works only with key on accessory
any Ideas?
I am off to go out to shop to rip this pig a part I will check back often on my phone
Starting at the key switch and working out from there
this is on my 1990 2wd 5 speed
thanks
Brice
Old Sep 14, 2010 | 10:39 PM
geddy's uncle's Avatar
I've got no damn idea, but, needed a place to put a new post (noobie/can't use PM's until past 10 posts)
Old Sep 14, 2010 | 10:42 PM
tiremann9669's Avatar
Fusible link possibly
So how many more do you need
Last edited by tiremann9669; Sep 14, 2010 at 10:42 PM. Reason: Automerged Doublepost
Old Sep 14, 2010 | 11:12 PM
Site Sponsor
No problem man good to have ya on the site!
I was thinking that but most all have been replaced with fuses
hmmmmm
I need to dig up my old wiring diagrams
Old Sep 15, 2010 | 07:19 AM
KD93's Avatar
They say that 90% of all eletrical problems are ground related. The other 10% are just a complete PITA!!! In your case Brice, I'm hoping it's going to be the ground on your battery. This happened to me 3 or 4 years ago, before I knew anything about engines/electrical etc etc. Went out one day to fire her up, nuthin. Called a fella to come out and take a look, just needed a new ground connection.
Old Sep 15, 2010 | 10:39 AM
tltruckparts's Avatar
i would check for ground problems too. its just gonna be one of those problems that is only gonna be fixed with a dvom, a couple beers, and some time
Old Sep 15, 2010 | 10:58 AM
Site Sponsor
Default Re: Give me a hand with this.........
Lol yep still no luck yet grrrrrr
Sent from my DROIDX using Tapatalk
Old Sep 15, 2010 | 11:04 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
try a extra ground from the battery to chassis.
Old Sep 15, 2010 | 11:37 AM
Site Sponsor
thanks Tony I have 2 extra grounds already and have tryed to clean or rewire everyone I could find (as said above 90% is ground related) and I still have no luck the dash is riped apart there is verry little OEM wiring left now
kinda of doing a re-wire
Old Sep 15, 2010 | 01:05 PM
Alligator Vinny's Avatar
Site Sponsor - Alligator Performance
I ran into this on a customers truck a few years ago. On the front side of the fire wall in the engine compartment there are some electrical solenoids and relays. I went though everything trying to get his gauges working again. I pushed on the two black relays on the fire wall one of them clicked it had vibrated lose and the gauges worked fine.
Not sure if this is the problem on your truck but might be worth a shot at this point!
