moog 7226s springs
Old Sep 14, 2010 | 07:38 PM
deanhinsley1963's Avatar
Question moog 7226s springs
Do you run them? Do you like them? I would like to level my dually will these do the trick?
Old Sep 14, 2010 | 09:25 PM
white93's Avatar
I run them and they ride a little better than what they replaced.I don't have many miles on them so I'm hoping that they will ride better with some miles on them.
Old Sep 15, 2010 | 01:47 PM
But did they level the truck?
Old Sep 15, 2010 | 03:49 PM
Mark Nixon's Avatar
There IS a heavier duty option than those springs.
It's an application that was suggested to me by a fellow on another forum, don't have a part number.
Mark.
Old Sep 15, 2010 | 05:02 PM
Begle1's Avatar
Well thanks Mark, that's real helpful.
That's like saying, "I know of something better than sex, but I can't recall what it is...."
Old Sep 15, 2010 | 05:18 PM
Mark Nixon's Avatar
LMAO, leave it to you to come up with that!
The application is for the last of the "old body" GM 1 ton Dually Crew cabs, something like '86-'92.
The wire diameter is slightly larger, the free/installed heights are a smidge more, but they use the same inner diameter.
The wire size is what really makes the difference, of course THAT is the dimension that eludes me.
I went to Rockauto with the app. and did the comparison and it did indeed come up with a usable difference.
Mark.
Old Sep 18, 2010 | 11:50 AM
does anyone else have an opinion about these springs?
Old Sep 18, 2010 | 12:05 PM
LOGANSTANFORTH's Avatar
Mark.
The last of the square body 2wd 1 ton dually truck springs is what your talking about...
The 7226 spring is used in alot of suburbans also, I found this by going to Rock Auto also...
Old Sep 18, 2010 | 11:39 PM
white93's Avatar
It did mostly level mine out.It sits about an inch lower in the front,but I have an add a leaf in the rear spring pack.If it wasn't for the add a leaf it would be level.The pictures in my gallery show the truck before the 7226s springs.
Old Sep 27, 2010 | 06:40 AM
Bob Beauchaine's Avatar
The Moog 7226S is the wrong spring for a 1st gen dually. You want the Moog 5716S spring.
7226S Load rate per in = 1135 lbs/in
5716S Load rate per in = 1430 lb/in
In addition the 5716S is slightly larger.
2FordStrokers
Tire, Wheel & Suspension
Jan 5, 2015 09:23 PM
POWERSTROKEMANIAC
Dec 30, 2014 11:32 AM
jcottonoir
Nov 28, 2014 12:38 PM
Sep 29, 2014 03:00 PM
