Power Loss
Old Sep 13, 2010 | 07:16 PM
Sandman8105's Avatar
Default Power Loss
Yesterday the truck was running fine. Today, it acts like it is loosing power so I have to keep my foot on the gas. Could this be caused by bad fuel or clogged injectors? Or possibly lift pump or i.p. problems? Crawler, I need your expertise.
Old Sep 13, 2010 | 07:45 PM
fordman69's Avatar
when was the last filter change?
Old Sep 13, 2010 | 07:51 PM
Just changed the fuel filter about two weeks ago.
Old Sep 13, 2010 | 08:03 PM
DieselCrawler's Avatar
how full are your fuel tanks? also does it act like it is running out of fuel or not. any smoke?
Old Sep 13, 2010 | 08:51 PM
Each has about a half a tank. It does act like it is running out but no smoke.
At least a half a tank or more.
What about low battery voltage? Could that be causing it?
Last edited by Sandman8105; Sep 13, 2010 at 08:51 PM. Reason: Automerged Doublepost
Old Sep 13, 2010 | 09:59 PM
fordman69's Avatar
Low voltage wouldent do it sounds like fuel problem first I would top off tanks the pick up tubes and anti gel valves brake off the pick up tube. Then any wet spot on your fuel system could let air in the lines if all this checks out check lift pump should have 5/6 psi at the shrader valve up at the filter.
Old Sep 13, 2010 | 10:34 PM
Just wondering because the batteries went dead. Not sure yet if they are junk or the alternator is bad. That is why I was wondering about a voltage problem. Second time today. Yesterday was fine though.
Old Sep 14, 2010 | 11:30 PM
As long as it's running and the alternator is turnning, its fine. Kill is and it won't start. Changing the batts. friday. Still, would that cause it to act like it has a fuel problem?
Old Sep 15, 2010 | 07:15 AM
shouldnt. these beast do need to crank fast. i recommend getting the biggest batts u can get, in CCA. i am running 1000 CCA batts. cranks really fast.
Old Sep 15, 2010 | 11:47 PM
Crawler, what kind are ya running and where did ya get them?
