FT. LBS to INCH LBS on trani adjustments
Old Sep 13, 2010 | 12:13 PM
Billy D's Avatar
Default FT. LBS to INCH LBS on trani adjustments
Ok, im a dumb ***, my torqe wrench is ft pounds. Is there a way I can convert ft lbs to inch lbs? Lucky for my my dumb *** attack didnt fk me, but I did loosen the lock nut, and started to turn the adjustment screw. I hope im not F'd. I will never fk with my trani again! Any info would be greatly appreciated. This is my rear band adjustment screw I'm refering too, I'm changing my fluid, and thought I was gona adjust my front and rear bands. WTF was I thinkn!
Thanks
Billy D
Divide by 12
Old Sep 13, 2010 | 12:41 PM
Turbo Performance's Avatar
Thanks
Billy D
Divide by 12
Pretty sure you can go rent an in-lb torque wrench from local auto parts stores. Just leave a deposit and when you bring the tool back they give your money back. That's the only way you're going to be 100% accurate. Using a ft-lb wrench and converting to in-lb isn't going to be the best way to do it.
Old Sep 14, 2010 | 07:26 PM
Billy D's Avatar
I called around, no one had one to rent, and I couldn't find one close in my area, so I buttoned it back up with new fluid n filter till I get one. Sucks, but I difnt wana F nothin up.
Old Sep 15, 2010 | 07:38 PM
dslfrk's Avatar
you can use a ft. lbs. torque wrench for inch. lbs. only if your ft. lbs. goes low enough. for example if the torque spec calls for 72inch lbs, you can use a ft lb wrench at 6 ft. lbs.
its simple math. 12inch. lbs. for 1ft. lbs. so
12inch lbs = 1ft lbs
24inch lbs = 2ft lbs
300 inch lbs = 25ft lbs
etc......
hope this helps.
Old Sep 15, 2010 | 07:58 PM
tiremann9669's Avatar
Usually your ft lbs torque wrench is gonna be outa range for inch lbs, don't you have any mechanic buddys you could borrow one from ? I've heard of people goin to Sears and buyin a specialty tool and then returning it when done, but I would never do or condone anything like that.
Old Sep 15, 2010 | 11:04 PM
That's exactly why I recommended getting an in-lb wrench. Converting with "simple math" doesn't exactly work if the torque wrench isn't accurate down that low.
Old Sep 15, 2010 | 11:15 PM
Well if you want to come to wny you can use my inch lbs wrench
I agree
Last edited by tiremann9669; Sep 15, 2010 at 11:15 PM. Reason: Automerged Doublepost
Old Sep 16, 2010 | 07:55 AM
RAW's Avatar
RAW
Depending on the torque and price range, you could buy a electronic torque wrench. I have the Snap-On 3/8" version, and it reads Ft.-Lbs., In.-Lbs., and Nm. It shows live value of torque as you go, not just a click or beep. Very handy for setting preload on bearings via. rolling torque.
Old Sep 16, 2010 | 12:33 PM
I bet she comes with a nice price tag too
