is this normal smoke
Old Sep 12, 2010 | 08:22 PM
dodgeram082500's Avatar
Default is this normal smoke
got a little smoke coming out of my oil cap/ oil check tube wondering if this is normal for a truck with 50000 miles on it and if its anything to worry about trucks is running really good just puffing a little nearly non existant at idle ,but when high idleing at 1500rpm it gives you this
this vid is high idle 1500rpm
also I havent changed my cvv could this cause this
Old Sep 12, 2010 | 08:28 PM
wildbill's Avatar
How high have you been running the EGT's?? May have a burnt exhaust valve.
Old Sep 12, 2010 | 08:30 PM
since the new turbo 8000 miles ago she hasnt seen over 1250 before that I had a run of 1400 on its record
Old Sep 12, 2010 | 08:34 PM
wildbill's Avatar
Might need to latch onto a few thousand pounds, and make a road trip. Probably got a lot of soot buildup on the valves.
Old Sep 13, 2010 | 02:02 PM
Farmboy 2.0's Avatar
Sounds like the rings. That is usually what happens when the rings are shot
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
ASarsano
Oct 15, 2014 05:33 AM
