98.5 5.9 CUMMINS WILL NOT START
Old Sep 12, 2010 | 04:46 PM
chester601's Avatar
Default 98.5 5.9 CUMMINS WILL NOT START
truck was running fine , I stopped at a light ,when the light turned green I hit the accelerator and the trunk would not move the engine was running but real slow
i shut it off and now it will not start . any ideas what i should check next ???
the fuel pressure was between 10 and 12 psi with stock pump , but i was not looking at the gauge when this happened . I just changed the lift pump today with a fass direct replacement pump -still will not start .
Old Sep 12, 2010 | 08:31 PM
biged681985's Avatar
do u have any codes? or have u not checked? did u bleed the fuel lines when u tried to start it?
Old Sep 12, 2010 | 09:16 PM
RAW's Avatar
RAW
APPS reset?
Old Sep 13, 2010 | 02:10 PM
Cain379's Avatar
check for codes, but sounds like it could be the inj. pump
Old Sep 13, 2010 | 05:43 PM
chester601's Avatar
codes 0253-1693-1688
reseting apps now
codes -0253-1693-1688
thanks
Last edited by chester601; Sep 13, 2010 at 05:43 PM. Reason: Automerged Doublepost
Old Sep 13, 2010 | 05:52 PM
blkjack's Avatar
My buddys truck did the exact same thing punching it leaving from a light and ran rough and then would not start. And had the same codes as well.... I did try the apps reset procedure, new lift pump, new fuel filter, bleeding the lines, cleaning the MAP and AIT sensors, and still nothing, sadly we just put a injection pump in it friday night and the truck fired right up. So I would have to say you are looking at a new injection pump.
Old Sep 13, 2010 | 06:13 PM
chester601's Avatar
thanks
Old Sep 13, 2010 | 11:25 PM
P1688 is usually the VP-44
Have you cleared the codes?
ronstop
Feb 26, 2015 09:48 AM
mcclusk
Feb 21, 2015 09:50 PM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
drivecumminsridered
Nov 13, 2014 06:31 PM
