what harmonic dampner are you using at 4000rpm?
Old Sep 12, 2010 | 12:42 PM
jpfiero's Avatar
Default what harmonic dampner are you using at 4000rpm?
I've got a ppumped '93 12v, and I want to install a 4k governor kit, I noticed that the '96 engine I got the ppump from has a larger harmonic dampner.
Do you guys just use the factory dampner at high rpms? It looks like the dampners on these engines are neutrally balanced since there is no way of indexing them to the crank, so is it safe to use the larger dampner on my engine?
Thanks
Old Sep 12, 2010 | 01:15 PM
BC847's Avatar
I run the Fluidampr on my '93. It's seen a little more than 4000rpm with no issues. I don't know about the later CTD dampers.
Old Sep 12, 2010 | 10:17 PM
jpfiero's Avatar
Well I looked at the fluidampr website and it looks like all 12v cummins are internally balanced, so I should be safe with either dampner.
How do you like the fluidampr? Did you notice a difference?
Thanks for the reply
Old Sep 15, 2010 | 10:32 PM
BC847's Avatar
No seat-of-the-pants improvement parse. The engine does idle smoother and seems to wind-up easier, if that makes sense.
FYI: A viscus-fluid type harmonic damper (like the Fluidampr) is standard equipment on the marine and some industrial Cummins 4bts and 6bts. It's maintenance is covered in the Cummins service manual.
Old Sep 15, 2010 | 11:35 PM
jpfiero's Avatar
interesting, I might have to look at getting one of those.
12Vdodge
8
Dec 15, 2015 01:00 AM
Brougham455
6.2L & 6.5L Performance
Oct 21, 2015 07:39 AM
