98 6.5 turbo
Old Sep 12, 2010 | 11:16 AM
rick's Avatar
Default 98 6.5 turbo
was wondering if I should try pinching off the vac line to the waste gate for more power?
truck seems to blow black smoke under tow and loss of power?
no leeks on the cross over pipe, runs strong when not in tow.
any help please?
Old Sep 12, 2010 | 08:12 PM
Woody35's Avatar
pinching it off would mean the wastegate would be open all the time. you need to wire the wastegate shut but dont tow with it because the boost could be harmful to the engine
Old Sep 15, 2010 | 12:07 AM
Walking J's Avatar
You likely have a leak in the vacuum lines that provide vacuum to shut the wastegate. Easy fix.
Old Sep 15, 2010 | 06:14 AM
rick's Avatar
where do I start and what do I look for, there is vacuum at the line with a good pull?
Old Sep 15, 2010 | 02:52 PM
Walking J's Avatar
Just follow the vacuum lines backwards from the turbo checking for any cracking at all, or to see if they've come apart. Just takes a little time.
Old Sep 24, 2010 | 02:52 PM
rick's Avatar
how do I find the leek tried everything? where to look?
Old Sep 25, 2010 | 11:39 AM
Woody35's Avatar
see any cracks in the plastic?
Old Sep 25, 2010 | 12:35 PM
Crazy's Avatar
Rick
look at the arm on the wast gate with engine off then start it and look at the arm if pull up then screwdrive try pushing down on wast gate arm if you can't most likey there no vacuum leak and if that arm don't move when starting the truck try tapping on the Wastegate solenoid they get stuck
other thing i don't know what mods you have done to truck or how many miles on it maybe clog cat that cause loss of power
Brclouse
Nov 18, 2015 08:44 AM
Grey Rhino
Aug 12, 2015 06:47 AM
klein444
Feb 27, 2015 01:53 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
Snoobly
Dec 11, 2014 11:59 AM
