Low Tire Pressure Light
Old Sep 11, 2010 | 09:14 PM
jball2500's Avatar
Default Low Tire Pressure Light
Does anyone know any tricks for turning off the low tire pressure light? I put an aftermarket set of wheels and tires on my truck and the dealership told me that it cant be turned off now... Which I dont entirely believe. There has to be a way!
Old Sep 11, 2010 | 09:20 PM
tiremann9669's Avatar
I believe if you use the valve stems from your old wheels with the TPMS sensors, your TPMS will work as normal. If you're leaving them mounted you could buy another set from the dealer, they're probably pricey. Otherwise you could remove the bulb from it
Old Sep 11, 2010 | 09:23 PM
jball2500's Avatar
Thanks for the reply, I have the sensors from the factory wheels in my new wheels, could mean one of them is bad....
Old Sep 11, 2010 | 09:50 PM
Probably, does the system tell you wich tire is low ?
Old Sep 11, 2010 | 09:57 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have to keep 70 lb in my tires to keep the light off
Old Sep 14, 2010 | 08:59 PM
Big Earl's Avatar
front tires call for 67#
and back on lite load call for 45 and heavy load 67 so I run 67 to 70 and kep on heavy with no problems
Old Sep 15, 2010 | 01:44 PM
barkrulz's Avatar
had the oil changed and they dropped my tire pressure from 67 to 42 and the light came back on. Putting leveling kit and 35s on in a couple weeks so i'm going to wait and check it again, i'm wondering if 20" wheels make any difference, wouldn't think so if the sensor was picking it up at 67lbs.
Old Dec 31, 2010 | 09:31 PM
cummingsgreat's Avatar
doesnt matter what size tire or wheel you have on your truck, the computer is set to the pressure listed on the side of you door. i have a 09 and its set for 80 psi (which means anything under a 10 ply tire) the light will come on and stay on. i put 315s (8 ply) 50psi and i cant keep the light off. took it in for a oil change and the service mger told was set to the computer. i even trying letting the air out of the spare to 50psi so that all 5 be the same and didnt work! you find another way let me know
Old Jan 3, 2011 | 09:35 AM
barkrulz's Avatar
Default TPMS
i was thinking more along the lines of the distance between where the sensor and receiver(s) are, no idea where the signal from the sensor is picked up.
Anyone know>> does the sensor send a signal of the pressure OR a good/bad signal. If the signal is just good/bad you could probably cheat it by getting a set that are in a diffrent pressure range.
Old Jan 3, 2011 | 01:00 PM
jl ws-6's Avatar
There's a way to trick the truck....
Take the stock air valves, get a piece of pipe, and install the 4 monitor's in the pipe, so it looks like it has the 4 monitor's installed, like valve stem's in the wheels...
Drill/tap a hole in one end cap, put a presssure ga. there, so you can see what the pipe pressure is...
Other end, drill/tap and put an air fill bung in. Pressurize the pipe like you would a tire, spray with soapy water, get rid of any leaks, once you have it sealed up right and will hold pressure, air up to 75 psi or whatever, and stick said pipe under the seat.
Kind of hack... but a buddy of mine did it with his ford, and it works perfect. No more tpms light on, and he's got his aftermarket 22's on the truck, and runs about 45 psi in the tires, and it's happy.
I'm sure this would work with dodge, chevy, any car with a tpms system on it actually.
Someone should just start selling a setup like that... I'd bet that it would sell like mad
