waste gate question
Old Sep 11, 2010 | 08:46 PM
kyle davis's Avatar
Default waste gate question
since i put twins on the super b( hx40) and ht 60 with im guessing a 23 housing i have only really been able to get 40lbs boost.. im guessing its because i never changed the wastegate setting. how do i change it? lenghten the rod or shorten it? if thats not the problem any other thoughts would be helpful
Old Sep 12, 2010 | 11:45 AM
RAW's Avatar
RAW
Shorten the rod, if you are looking to do it that way. You can always pinch off the hose as well.
Old Sep 12, 2010 | 11:42 PM
sstockton's Avatar
What is the pressure like between your two chargers? I am guessing that your top charger is making all the boost and the bottom isn't pushing much air through. You want the wastegate on the top charger to regulate it to a PR of roughly 2-2.4:1.
Sean
Old Sep 13, 2010 | 06:31 AM
kyle davis's Avatar
i have no idea how do i find out?
Old Sep 13, 2010 | 07:41 AM
RAW's Avatar
RAW
Have to put another gauge in to measure boost from the Primary.
Old Sep 18, 2010 | 11:23 PM
kyle davis's Avatar
ok i put a guage to it and the big primary is pushing like 7 or 8 max and both are hitting 35... any ideas to help? i should have plenty of fuel, and i can tell they both spooling up i have tried 2 primarys as one was putting oil in the intake tube and the second one idont know much on but the look similar
Old Sep 18, 2010 | 11:28 PM
RAW's Avatar
RAW
Only 7 or 8, eh? I know my buddys 12V pushes 16 out of his S400, totaling 65-68 at the intake.
Old Sep 19, 2010 | 09:10 AM
kyle davis's Avatar
yea dont make much sense i think the oil leaker did more but i didnt get a pressure check on it b/c i didnt want oil everywere dont know what to do really ... i think im gonna go back to a single till i can afford a new ht60
Old Sep 19, 2010 | 04:18 PM
sstockton's Avatar
Ambient pressure at your elevation is 14.01psi. So your primary is running at a PR of approx 1.5:1. And your secondary is running at a PR of approx. 2.22. The secondary probably right about where it wants to be, It could stand to go a little higher, but really you need to get that bottom charger spinning to get your airflow up. That super b probably could stand to run up to about 3.0 and similarly with the ht60 as larger turbos operate better at higher PR's. Anyways, I think that wastegating is probably about spot on, but you need more fuel to get that bottom charger spinning.
Sean
Old Sep 19, 2010 | 05:43 PM
BIG NIG's Avatar
blah blah blah blah
get your bottom charger fix'd then see how it does
