1998 24v code p1389 help
Old Sep 11, 2010 | 07:16 PM
aaronmoore's Avatar
Default 1998 24v code p1389 help
just got a code on my truck p1389 is says no asd relay voltage at pcm any ideas thanks aaron
also it lacks power and has a rough idle
Last edited by aaronmoore; Sep 11, 2010 at 07:16 PM. Reason: Automerged Doublepost
Old Sep 12, 2010 | 08:01 AM
turbo20psi's Avatar
The ASD relay shuts down the engine in case of a roll over.
Check your relays in the PDC(engine compartment). Check for any fuses that are blown.
Old Sep 12, 2010 | 11:20 AM
aaronmoore's Avatar
yea i switched the relay out with another one and it still the same.
one guy told me it could possibly be the pcm cause when i first crank it it takes a min for voltage gauge to come up and my oil preessur gauge quit workin then sometimes will work any ideas thanks
Last edited by aaronmoore; Sep 12, 2010 at 11:20 AM. Reason: Automerged Doublepost
Old Sep 12, 2010 | 05:24 PM
turbo20psi's Avatar
The voltage regulator my have went south.The voltage regulator is in the PCM but you do not have to buy a new PCM.
Old Sep 12, 2010 | 05:25 PM
aaronmoore's Avatar
so where do I get one and how do I change it? Thanks Aaron
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Nov 24, 2014 08:20 AM
UC Kid
Nov 7, 2014 10:56 PM
