Amsoil Visit - Amsoil
Manual Synchromesh Transmission Fluid 5W-30
Old Sep 11, 2010 | 03:13 PM
LORDDiESEL's Avatar
Default Manual Synchromesh Transmission Fluid 5W-30
Product Code: MTFQT-EA
Hi there.
Can i use this in my 06 f350 ZF6 and T/C? I've heard this is much better to run than the ATF ford uses.
Thanks
Old Sep 12, 2010 | 03:56 PM
Heath's Avatar
Authorized Amsoil Dealer
Honestly don't know if it CAN be used or not. I do know it is not the recommended fluid according to Ford specs. For this you would want either the ATF or ATD product that we have. These two are great products.
Old Sep 14, 2010 | 07:07 PM
LORDDiESEL's Avatar
damn it! I know the 06 07 use ATF. The 08 09 use gear lube, but know onw can tell me the difference.
Old Sep 30, 2010 | 08:01 PM
LORDDiESEL's Avatar
Heath, Ford has swapped out the ATF and is getting dealers to run Ford Synth MTF that is used in the 08 09 F250/350.
What does AMSOIL suggest for 08 09 manual trannys?
Old Sep 30, 2010 | 09:53 PM
Heath's Avatar
For the 08 and newer in the manuals they are suggesting the GL-4 rated gear lube. It's our MTG product. Same fluid that's used in the NV4500 trannys.
Old Sep 30, 2010 | 11:27 PM
LORDDiESEL's Avatar
XT-M5-QS is what ford is now replacing the ATF with. At 20 bucks a quart, i'm going amsoil. Can i place my order through you, heath?
Thanks for the info.
Old Oct 1, 2010 | 05:37 AM
Heath's Avatar
Sure can. Looks like you will need 6qt. I'll PM you a price. Then just call when ready.
thanks,
Heath
641-420-6677
Old Oct 1, 2010 | 06:04 PM
01quadcab's Avatar
and people think amsoil is expensive
Old Oct 22, 2010 | 12:45 PM
D-Roc's Avatar
I switched my 06 out to MTF from ATF. Always been a little notchy, but it cleaned up a little with the MTF product. I've never really been much of a fan of ATF in a manula trany, myself.
Old Oct 23, 2010 | 10:48 PM
LORDDiESEL's Avatar
Running the amsoil MTG and it shifts like butter!
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PD4Life
Aug 24, 2015 08:11 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
smokee
Nov 7, 2014 07:40 PM
